help!!!!!
Old Aug 24, 2003 | 05:36 PM
ionicswing's Avatar
help!!!!!
i just got finished puttin on a new fuel filter........but it still wont crank. the fuel pump primes everytime u turn ignition on. any sugesstions on how to get it running????
Old Aug 24, 2003 | 10:05 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
it won't crank, like you turn the key and u get a click or no sound?
or the starter is going and cranking the motor but it won't start?
Old Aug 24, 2003 | 11:04 PM
nadster's Avatar
Car: 89 RS
Engine: 2.8 (the cruiser)
Transmission: 700R4 (TransGo Kit, VetteServo)
Hm, I'm assuming the starter turns the engine over. First off, I would go and check your ignition system for spark and see if your problem lies there. You could have a bad module, coil, rotor or a cap even. If that stuff is okay, (blue spark or bright bluish spark), then I would go and check your fuse block and see if there is anything blown there that might cause your fuel injectors to not spray. Hm, other than that, I'm not too sure depending on what the situation is. Might have to have someone run a scanner or a scope on it and see if the ECU is throwing any codes. Good luck.
-Dan
Old Aug 24, 2003 | 11:18 PM
ionicswing's Avatar
the starter works....the engine turn and turns......but never starts!! before i replaced the fuel filter, it would start, but wouldnt stay running. now i replaced it, and the fuel leaked out of the open gas lines while changeing, could it be air in the lines causeing this, and if so how would i fix that!!
Old Aug 24, 2003 | 11:33 PM
nadster's Avatar
Car: 89 RS
Hm, odd. I've replaced them many times and it would run. Hows the starter? Can you hear it prime? It's also possible that the starter relay could be bad. I've replaced that before as well, the relays are fairly cheep. Should be on the drivers side of the firewall. Don't remember which one it was exactly though.
-Dan
Old Aug 24, 2003 | 11:39 PM
ionicswing's Avatar
i dont beileve the starter would be the problem.....i havent had any problems what so ever starting, every time i start up...it takes less than two seconds, and never had it drag out....even under cold weather!!
Old Aug 24, 2003 | 11:41 PM
ionicswing's Avatar
is it possible, that the computer has messed up, and telling it something that it really shouldnt??
Old Aug 24, 2003 | 11:55 PM
I don't know what happens when you do this...but is it possible you put the filter in backwards?
Old Aug 25, 2003 | 12:11 AM
ionicswing's Avatar
im pretty sure i didnt......but i will double check!!
Old Aug 25, 2003 | 09:28 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Get a fuel pressure gauge.
How long have you been working on this? Isn't the gauge worth it by now?? I mean seriously dude, we can only help so much before we're just throwing crazy ideas out there.
Hell I could tell you that your TPS is stuck at WOT and the ECM is going into clear flood mode and not turning the injectors on- and you could go through the diagnostic and $40 for a new sensor when it turns out your fuel pump was bad the whole time, and now you're out $40 for replacing the good sensor, days worth of diagnostic time, AND you've gotta replace the pump still!
See what I mean?
Old Aug 25, 2003 | 12:02 PM
ionicswing's Avatar
could the fuel pump be bad, even when it primes everytime???????
Old Aug 25, 2003 | 05:37 PM
ionicswing's Avatar
diagnosis!!..........fuel pump is ok, its not gettin any spark!! any ideas of what specifically it would be....or should i just replace the module, cap, rotor, and coil all together???
Old Aug 26, 2003 | 12:08 AM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
Check the module. I think Auto Zone can test it for you if you don't have a way to test it. That might be it.
Old Aug 26, 2003 | 06:43 PM
ionicswing's Avatar
thx guys!! turs out the module had a burn spot on it, but i went and replaced the module, cap, rotor, and coil, and the problem is fixed. thx again.
