Oil Pan Gasket '84 GMC vs '86 Maro
Old Sep 8, 2003 | 11:08 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Putting an '86 Camaro FI block into my '84 2bbl GMC Jimmy.... I need to swap oil pans because of the front differential. (Jimmy has a deep sump pan). Will the pans be interchangeable? I havn't gotten the '86 block out yet so I can't compare the two. (Doing this at my friends house 60miles away) and want to know what oil pan gasket to use.
Parts stores as me if I have a goodwrench 12bolt pan on the car?
Old Sep 8, 2003 | 01:38 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I know an '88 Camaro 2.8 and '93 2.8 Blazer oil pans are different... is the front of your Jimmy's oil pan V shaped, or U shaped?
My '88 Camaro oil pan has a U shaped front...
Old Sep 8, 2003 | 07:28 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
just go to a parts store & ask to see both
Old Sep 8, 2003 | 07:41 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes and no. Front timing cover may need to be changed. Oil pickup tube is different so of course it needs to be changed. I know hen I did my version of the 3.4 GMHP put me in the hole $2200 long block S10 blazer boogie all the parts needed to be changed but you already knew about the top end so no supprise there.
Old Sep 8, 2003 | 10:06 PM
It looks like there were a few more bolts, on the front of the gasket of the jimmy than the camaro... and the back bolts had bigger holes on the jimmy.
Can I just swap the pick up/pan/timing cover from the jimmy to the camaro block?
Old Sep 8, 2003 | 10:25 PM
Engine: 5.7 / 7.4
If I remeber correctly, the AZ computer asks if you have a regualr pan or goodwrench pan. that might explain the different number of bolt holes in the gasket/pan/block.
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
