Code 43 help
Old Sep 9, 2003 | 10:04 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Code 43 help
I am getting a code 43, after looking this up i am a little confused about where to start.
According to the description i read, it has to do with low voltage to the timing circuit?
What should i start with? Could this be knock sensor related?
Any help would be great, i would like to start on it tonight, just need some direction first.
Old Sep 9, 2003 | 11:36 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
code 43 seems to be low voltage EST? I'd test teh knock sensor, and find out if your 3.1 has an EST relay module or something...
anyone have the actual flow chart diagnosis for it?
Old Sep 9, 2003 | 07:11 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Code 43 is electronic spark control ESC. Go to http://www.ece.ubc.ca/~jcoatta/6E3-A2-60.jpg and
http://www.ece.ubc.ca/~jcoatta/6E3-A2-61.jpg for the flow charts. These are for an '86 5.0L, but they should apply to your car. Reply to this message when you've downloaded them so I can remove them.
Old Sep 10, 2003 | 08:34 AM
9D1BURD's Avatar
Car: 1997 Z28
I am downloading them now, thanks. I was hoping for an easy fix, lets see how it goes.
Thanks again
anyone else wanna chime in?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
