Fan problem
Old Sep 23, 2003 | 10:01 PM
Mathius's Avatar
Fan problem
If you guys can't help me, I'll try heating and cooling.... My car has been apart for a few monthes, as I cleaned out the upper intake, bead blasted and painted it, repainted the valve covers, had the fuel injectors cleaned and flow tested, fixed my cruise control, replaced my heater box, painted my resevoirs, and changed all my hoses and convoluted tubing.
Upon restarting the car, I did the normal check for overheating, popped open the radiator cap, waited for the thermostat to open up, and added more coolant when it went down, checked the overflow. I drove it home, and I seem to come close to hitting the red area temp wise several times... I think the problem is my fan.
My fan doesn't seem to kick on until I hit about 230. I'd like it to kick on well before this. What's wrong here, or how do I change this at least? Is this hard to do?
Mathius
Old Sep 23, 2003 | 10:11 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
new fan switches are bout $12.50 at parts store. I belive it is in the pass head, rear, where the 3.4s have the pipe plug.
where in OH?
Old Sep 24, 2003 | 12:02 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Can you lower the fan on temp with a new switch, or do you have to modify the PROM?
Old Sep 24, 2003 | 07:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '90-'92 are controlled by the ECM. Don't know about the other years.
RBob.
Old Sep 24, 2003 | 11:02 AM
Mine's an '86. I assumed it was controlled by the PROM in my car, but I don't really have any reason to believe that.
Old Sep 25, 2003 | 09:36 PM
Mathius's Avatar
I have the 3.1. (92 camaro) What will a new fan switch do for me? Is mine not working properly? What is the fan supposed to turn on at?
I'm in lorain county.
Mathius
Old Sep 26, 2003 | 07:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Mathius
In order to use a separate fan switch you will need to wire it into the fan relay or the A/C pressure switch. The A/C pressure switch opens with high pressure telling the ECM to turn the fan on. Disconnecting the switch will cause the fan to run continuously. Can also ground the fan relay enable lead to turn on the fan.
The ECM trip point is high, too high, IIRC it is 228° F, I don't have the source with me at the moment for the exact value.
RBob.
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
