89 rs bad injector
Old Sep 26, 2003 | 11:28 AM
85 lg4's Avatar
Car: 89 TA
Engine: Fast !!
Transmission: slipinslide auto
89 rs bad injector
car runs a little rough and smells like gas.... how can I test them ?? or is there something else to look for.
Old Sep 26, 2003 | 11:56 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Possible, but doubtful its injectors.
Check and make sure you have full spark to all cylinders first.
Injectors will make it run rought, but smell like gas, no. Not unless you cracked the side of one, or leaking an oring or something.
Getting to where you can do ohm test on these is not fun. Other then ohm test, a normal DIY person doesnt have the tools to test any futher.
Old Sep 27, 2003 | 01:40 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
See: https://www.thirdgen.org/techbb2/sho...hreadid=202937
Old Sep 27, 2003 | 07:50 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Sunpro is selling their injector testor for like $20 in the garage sale section of their site , hint hint
edit: yup, see link above
Old Sep 29, 2003 | 02:59 AM
Engine: 5.7 / 7.4
yeah, check o-rings. Also check hard fuel lines along rail frame for rust leaks.
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
