Kudos to TomP!
Old Sep 25, 2003 | 10:48 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Kudos to TomP!
HE once again mentioned the garage sale over at http://www.sunpro.com , & I picked up their sensor probe & injector tester for less than $40 shipped
Oh the troubleshooting that can be done now :lala:
:hail: TomP :hail: , but then you knew that already
Old Sep 26, 2003 | 01:59 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I'm considering the exact same purchase Project.
Old Sep 26, 2003 | 06:00 PM
Engine: 5.7 / 7.4
got the goods already, standard ups too!
Amazing how tests the probe sensor will do. Maybe I cain finally ge tthe black smoke under control, since most of the tests refere to black smoke as a symptom.
Old Sep 26, 2003 | 07:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Didnt it sat that, that tester is to be use in conjunction with their special fuel pressure gauge??? Does it work without that gauge???
It is a good price for it though they are on ebay for $30 now.
Matt
Old Sep 26, 2003 | 11:00 PM
Engine: 5.7 / 7.4
I already have a fuel gauge testor. That is used for the fuel injector tests, leak down & all, checking the pressure drop. You wont need a gauge to test the harness though.
Old Sep 27, 2003 | 01:11 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! Anything I can do to get us quality tools at cheap prices, I'll do! Glad to hear the stuff came fast. I have the injector testor too, haven't had to use it yet (luckily).
Don't forget http://www.toolparadise for specialty stuff, too (like, oh, say, an OTC balljoint press!)
Old Sep 27, 2003 | 04:16 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
whats an OTC balljoint press, i rented a regular balljoint press fram AZ for free.
Old Sep 27, 2003 | 07:25 PM
Engine: 5.7 / 7.4
I have the big $99 one myself. Pirated a bdamaged return. The threads on the big screw were jacked so I dremeled them back. Not sure on the other type of ball joint press. What's the part number?
Old Sep 27, 2003 | 10:41 PM
I said screw it with trying to get the ball joints out and bought some brand new control arms (z28 arms) which turned out to have the ball joints and bushings already installed. I just ordered the spring isolators from the dealership and I have to get the bolts from gmpartsdirect (thanks to Tom for the part nums).
Old Sep 29, 2003 | 05:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
OTC 7249; OTC is a "Professional" tool company... kinda like Snap-On. They're a division of SPX. See more info at http://www.otctool.com ... oh and I bought it because I wanted to.
fasteddi
Sep 10, 2015 09:32 AM
squirrelybird
Feb 19, 2003 08:25 PM
loomdog32
May 1, 2002 10:21 AM
CaliCamaroRS
Mar 12, 2002 12:08 AM
