ECM not throwing codes
Old Oct 1, 2003 | 09:59 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Its a 91 3.1 5 spd Camaro.
Im having a problem with my idle a bit, if im driving the car and start to slow down, sometimes the car will die. The rpm will only sometimes drop below 800 and the car will sputter, sometimes dies, sometimes picks back up. Only happens when slowing down, any other time the car is fine. I have all new ignition parts, coil, spark plugs, wires, pickup coil, spark module, rotor, cap, and it is timed correctly. I notice when I unplug my TPS and IAC the computer won't throw a code anymore. If I unplug the TPS the car will not idle, but if I unplug the IAC it will. Any suggestions?
Old Oct 1, 2003 | 10:02 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Has your IAC been cleaned lately?
How's your fuel filter?
Those are 2 common culprits of stalls.
What's your idle speed set at also? If you take the car out of gear abruptly and the idle is too low it'll stall. Try cranking it up 100-150 rpms or so and see what happens.
Old Oct 2, 2003 | 12:48 AM
funstick's Avatar
does your speedometer work ?
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
eustodp
Sep 20, 2015 05:09 PM
RyanJB
Sep 2, 2015 01:27 PM
