maf sensor question
Old Oct 6, 2003 | 02:29 PM
paintshooter's Avatar
maf sensor question
ok here is the deal. I have had hesitation at 3/4 to wot and sometimes all the way through. Today I was checking all the connections to the sensors and I forgot to hook the maf back up. took the car out for a drive and it ran fine no hesitation. What does unplugging the the maf sensor do because it ran fine not hook up but when I plugged it back up it started the hesitation again.
Old Oct 6, 2003 | 03:12 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
If the MAF is not hooked up, the computer will substitute it's own preprogramed readings based on input from the other sensors.
It also means that your MAF is probably crapped. Do some tests for it & find out.
Old Oct 6, 2003 | 03:23 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I have been told that unhooking and hooking up the MAF with the battery still hooked up with fry the MAF. Your suppose to unhook the batt every time you touch the MAF connector.
Matt
Polish troops in Iraq (news - web sites) have found four French-built advanced anti-aircraft missiles which were built this year.
http://story.news.yahoo.com/news?tmp...nd_missiles_dc
Old Oct 7, 2003 | 08:30 AM
thanks for the input turns out it was the maf sensor, car runs great now.
Old Oct 7, 2003 | 09:49 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
everyone knows the troubles ive had with MAF sensors & everyone knows how much i hate them
Old Oct 12, 2003 | 03:07 PM
devianb's Avatar
Matt
I have been doing that for years, my MAF is fine. But most times I disconnect the battery before taking anything electrical off.
chazman
Aug 28, 2018 03:25 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
