Power loss
Old Oct 19, 2003 | 10:06 AM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
Power loss
My v6 has always ran pretty strong, until I made some upgrades. My v6 used to be able to do a small burn out, but not since the upgrades. A couple months ago I decided to scrap my stock muffler and install a cherrybomb, I thought removing the restrictive muffler would help but it didn't the car did not pick up as quick, but sounded a little better. then I decided to experiment with an exhaust cutout. after installation I didn't feel a real change in power but the car was even louder. I leave the cutout open most of the time now to **** off my neighbors and only close it when I see a cop. then I bought an slp cold air intake with a k&n thinking this would help greatly but I still didn't feel a difference. with all these upgrades, I feel like my car is running slower than ever. now when I try to burn out my car lags at 1500 rpm then starts moving, this lag is very frustrating. what is my cars problem? is there an easy fix (don't say get a v8)? I tried going back to stock with everything but it still runs the same way.
Old Oct 19, 2003 | 10:26 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Sounds like you need a tuneup, and perhaps check your timing - chain could be stretching!
Also, take your car to the track. You can't always go by the butt-o-meter.
Old Oct 19, 2003 | 10:34 AM
614Streets's Avatar
Raise your timing up a few degree's.
Old Oct 19, 2003 | 06:30 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I'd be willing to bet that you lost torque "butt-o-meter" so you don't feel fast...but all out, I think your top end is probably higher
Old Oct 20, 2003 | 12:02 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Opening up the exhaust, lowering the backpressure can sometimes take down your low end torque. The CAI should of helped with the low end. But do the tune ups, you will get it back.
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
