brake upgrade from other GM car ?
Old Oct 18, 2003 | 02:38 PM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
hi, I have driving my V6 bird for few month and found the brake are not good as my 93 Grand Am, can I use the brakes from other GM car to upgrade, there are not many GM cars in Taiwan, most of them are 80's and some new Buick and Caddy.
Old Oct 20, 2003 | 12:15 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
different types of brakes can work on the fbodies, but you can't take the brakes off of a front wheel drive and interchange them.
When was the last time you had brake service done to the vehicle?
Old Oct 20, 2003 | 02:26 PM
joekickass's Avatar
Engine: 2.8
Transmission: auto
I really don't know about the brake, I never do any "brake service" since I got him, what should I do first?
Old Oct 20, 2003 | 03:33 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
You do have front disc, rear drums, right?
Front:
Replace the pads, turn the rotors, rebuild the caliper, and replace the rubber brake lines.
Rear:
Replace the shoes/springs, turn the drums, replace the wheel cylinders
That should get you back in action again. If not, it might be time to totally flush the brake system out, and replace the fluid.
Old Oct 20, 2003 | 03:44 PM
joekickass's Avatar
Engine: 2.8
Transmission: auto
yes, my is disc/drum,
What do you mean " turn the rotor" "turn the drum" ?
Do you think that the brake will do the good job since they were "back in action", the reason I ask is because I don't know how the brake works in new condition.
sorry for my poor English.
Old Oct 20, 2003 | 04:06 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
turning the rotor:
you take the rotor to a brake shop and they put it on a machine.
the machine spins the rotor and a cutting tool touches it as it goes by, cutting a small amount off.
that makes the rotor smooth again. if the rotor is too thin or too warped that wont work and you have to get new rotors.
turning the drums is the same thing except the drum gets the inside turned.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
