nitrous on a 3.4L
Old Oct 20, 2003 | 01:33 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
nitrous on a 3.4L
Just wondering what I would need to do to strengthen a 3.4L engine to handle some nitrous. Besides the spray kit of course.
I'm wanting this engine to handle a shot of 75 HP about twice a month at MOST.
What would I need to do to her, what about tranny. Will be a T-5.
1987 Camaro
Old Oct 20, 2003 | 05:07 AM
ede's Avatar
ede
i wouldn't use a power adder without a forged rotating assembly. SFCs are needed reguardless, anything you do to strengthen the suspension will help, even if you don't have a power adder.
Old Oct 20, 2003 | 06:57 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Their are a few ppl on this board that run a 50 or 75 shot on stock internals.
I advise doing exhaust, intake, and better ignition first. Maybe better fuel system too.
Old Oct 20, 2003 | 08:00 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
should take a 75 shot just fine, may need larger injectors and bigger fuel pump tho.
Old Oct 20, 2003 | 04:21 PM
Daishi's Avatar
The 3.4L has the 17 lb injectors, what should I upgrade it to?
And if I've got TPI the fuel pump is in the gas tank right?
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
