3.1 trransverse vs. 3.1 normal mount
Old Nov 12, 2003 | 06:21 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Okay, I'm wondering the major differences between the LHO that's found in W-bodies versus the LHO found in F-bodies. I own an '89 GP with the LHO in it (old dog of a motor, but still has power) and the only thing I know is that it's distributorless - it uses coil packs and thus has the distributor hole blocked off. Say I wanted to swap that old thing into an F-body that had a junker 2.8 in it - what would be some of the difficulties and frustrations I would encounter?
Old Nov 12, 2003 | 10:12 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
the biggest and main problem is that the starter is on the opposite side of the block. if you can find a simple fix for this, you should be okay. you gotta make a new flywheel sheild for accomodate the starter. if you can put a distrutor in it, i'd guess that to be your best bet rather than switching computers to keep the DIS ignition.
Old Nov 12, 2003 | 11:08 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
and engine mounts.
Old Nov 13, 2003 | 12:51 AM
Car: 91 Camaro
i could be wrong but i think that atleast some fwd motors have the same mounts...
Old Nov 13, 2003 | 01:11 AM
biff85ta's Avatar
Car: 04 Vette
FWD block have the mounts in different locations as do fiero's.
Old Nov 13, 2003 | 09:15 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
The mounts are different on the vehicle, yes. The bolts on the engine block, though, should be the same?
Old Nov 13, 2003 | 09:07 PM
Engine: 5.7 / 7.4
Knowing GM, they're diffent, factory available only & cost too much. Especially from gmpartsdirect.com, or whatever that web site is.
Old Nov 14, 2003 | 01:28 AM
biff85ta's Avatar
Car: 04 Vette
Not according to what I found in doing research on what block to use after my fiero broke the crank taking the block with it.
Old Nov 14, 2003 | 01:32 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
They FWD and RWD blocks are not interchangable. Its not just the motor mounts, its the positioning on the block also. The Aluminum GM bowtie block has bosses for FWD and RWD- the only one that will interchange (as well as provisions for a left side and right side starter mount.
Old Nov 14, 2003 | 11:01 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
So, like, unless you're a masochist and realy really like daunting challenges, it isn't a very feasible thing to do, eh? Aw, crumbs. Well, unless I had the ability to fabricate some metal chunks, which I do not. I suppose it would be MUCH simpler for me to find a decent 3.1 or 2.8 to toss into a good-body/bad-engine firebird... I was just kicking the idea around, wanted to see what everyone thought of it. Thanks. Bummer - it would be so cool having a v6 firebird to use as a daily driver, and save the GTA as my weekend/going to church car. Hey I know - just BUY a decent v6 firebird!!!
Old Nov 15, 2003 | 01:57 AM
biff85ta's Avatar
Car: 04 Vette
Thank you and now I remeber where I got the info from my GMHPP catalog. That had been driving me nuts since I posted in this thread.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
