eliminating AC compressor AND air pump
Old Nov 16, 2003 | 10:23 PM
asylist's Avatar
Car is a 92 bird with 3.1, AC, auto trans. The clutch bearing in the AC compressor is going dry, and since the system is empty anyways, i'm thinking I'll just remove the compressor (or more specifically change the belt routing to no longer include the compressor). While I'm there, I'd also like to eliminate the AIR pump. Is this possible? I've seen the tech article for re routing the belt for removeing the AIR pump, but that appears to be for V8 engines. And I'd like to remove both the AC and pump.
Old Nov 17, 2003 | 10:00 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
IF e-check aint a prob, you can always do what I did w/the 3.4 routing, hit & miss. I had a good idea on how much shorter the belt would be, but it took about 7 tries to get just the right fit.
Old Nov 17, 2003 | 11:12 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
seamstress tape works well for finding new belt size
Old Nov 18, 2003 | 12:37 AM
asylist's Avatar
nope, no emmisions testing here in Detroit So it is possible to remove both? I wasn't sure that the tensioner and other pulleys would be set up properly.
Old Nov 18, 2003 | 01:08 AM
Engine: 5.7 / 7.4
Test it first. On my 3.4 belt setup, it is different than any factory configuration. I made sure everything was going to rotate the correct way.
Old Nov 18, 2003 | 11:43 PM
asylist's Avatar
do you have any pics or diagrams on how you did yours?
evilstuie
Apr 14, 2016 08:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
