V6 and torque...
Old Nov 29, 2003 | 05:28 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
V6 and torque...
Have any of you SIX-pack folks ever dynoed with diff. rear gears? If so, what kind of torque are you getting (ex. 4.10, 3.73?)??? I was thinking of a gear swap, but I ain't gonna bother if it ain't worthit on a V6.
Old Nov 29, 2003 | 08:33 PM
LT1guy's Avatar
Car: 1987 Trans Am
Its not going to affect RWHP numbers, though it will definitely make a big difference in the car. If you have an auto, I'd stay with 3.42, maybe 3.73 on a modded car (Redraif's cam/head 3.4 has 3.73s now). A 5 speed car might be able to take greater advantage of a 3.73, but I think a 4.10 would be too much.
Old Nov 29, 2003 | 10:01 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i am running 4.10s with an auto tranny. its fun to drive but i'm probably gonna try some 3.42s and maybe (hopefully) 3.73s just to see what it does. it accelerates rather quickly now but i think it may be hurting the top end a little bit.
Old Nov 29, 2003 | 10:10 PM
FbodTrek's Avatar
Ah
Well, I live in the "city" (more like suburban) I seldom go above 70 MPH. I just was wondering also, how much it would help my 0-60 time? Would it help at all??? If and when I do race, I go from light to light, about 1/8 miles usually...I don't mind cruising at higher rpms, my overdrive would probably work better with diff gears. Right now, it engages at 45-55 mph usually a bit on the high side of third gear. These cars probably run a LOT better with a 5 speed....MY EYE FOR A T-5!!!!LOL:hail:
Old Nov 30, 2003 | 10:49 AM
Car: 91 Camaro
if you put a posi unit in too....the 4.10s (or anything numerically higher than 3.23) will help your 0-60. mine seemed to spin the tires about the same with the 4.10s and posi and it would spin the RR with 3.23s and no posi. my rear tires are about 25.5" tall and 70 mph is about 3,000 rpm in OD. speedometer shows about 90 since i never changed the speedo gears.
Trevmust
May 5, 2012 04:44 PM
oxrabidus
Theoretical and Street Racing
Dec 11, 2011 12:41 PM
92RS_T-Top
Sep 28, 2011 05:18 AM
danziger
Apr 22, 2010 10:40 AM
Error404
Nov 8, 2003 10:56 AM
