Centerlink bad... alignment settings?
Old Dec 16, 2003 | 04:56 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Found out my centerlink is bad, when I went to get an alignment...
Anywho, I'm getting a new centerlink, both inner and outer tie rod ends, and ball joints. The idler arm is only a couple months old, and the pitman arm doesn't really wear, right?
Any suggestions on alignment specs? 245/50/16s on the front...
Old Dec 16, 2003 | 05:15 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
pitman arms can wear out, but not usually. I belive the test is if you cain rock it up & down a certain amount of distance.
Old Dec 18, 2003 | 08:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
85's right, I'm still on my +261,000 mile Pitman arm! It's not really a joint, it's more of a swivel. The idler arm attaches to the centerlink in the same manner (not a joint), BUT, it's the joint in the middle of the idler arm that wears out.
If you're on a budget, you usually don't have to replace the tie rod ends unless you bent one- they're "self-adjusting for wear", whatever the hell that means. At my last alignment check-up (when the guy rattled off everything that was bad), he didn't include the tie rod ends. He'd included everything else which I knew about, so I was a bit surprised the tie rod ends were still good. (See https://www.thirdgen.org/techbb2/sho...hreadid=153839 ) That's when I read in the GM book that the tie rods self-adjusted for wear.
But it's definately smarter to replace them while you're in there anyway. (Why pay for two alignments?)
Old Dec 18, 2003 | 09:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I hate to say this but the pitman arm is nothing more then a piece of metal with a hole at each end. Nothing to wear out. Parts house won't even have a number for it.
RBob.
Old Dec 19, 2003 | 09:21 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
set camber straight up at 0. caster the max it will allow depending on year either 4.5 or 5.5. toe depends on what you can take 0 is performane but can be vary darty otherwise use stock setting.
Ghettobird52
Apr 21, 2020 08:44 PM
deracer
Apr 11, 2016 12:04 AM
skip91
Sep 24, 2015 03:29 PM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
