For all you injector swapping guys
Old Jan 3, 2004 | 05:09 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Unless you do something RADICAL don't bother swapping in a set that wasn't made for your motor (i.e. 2.8 w/ 3.1 injectors). My car runs a lot smoother with the stock injectors, I can't smell gas from the exhaust like I could with the 3.1 injectors, and perhaps most impressively, my mpg went way up when I reinstalled my stock injectors. On the highway with the 3.1 injectors, I got just under 16 mpg, with my stock injectors I got ( drumroll please) 10mpg more, just under 26 mpg.
The only real mods to my engine are a powermax 2030, 1.52:1 roller rockers, and a cloyes timing chain.
Obviously this is a significant change, maybe not everybody would have this kind of difference in performance.
Make your own decisions, but I think this may answer a few questions
Old Jan 3, 2004 | 05:24 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Injectors are rated according to how much power the engine puts out. Plus gm's seem to run a little on the rich side anyway.
n/a
(hp x .50) / (injector qty x .80) = lb rating you need.
boosted
(hp x .60) / (injectors qty x .80) = lb rating you need
Old Jan 3, 2004 | 07:47 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
the problem with putting in bigger injectors is the computer is calibrated for a certain size (the injector constant) which must be compensated for in the computer chip. i have heads and headers done and i ran out of injector. now i have 19# fords with a custom chip.
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Jae992
Aug 27, 2015 09:07 AM
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 14, 2015 08:25 PM
