My MPFI intake port job!
Old Jan 11, 2004 | 03:04 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I took some pics of my port job on my intake. Let me explain a little on what I did
First, I looked into the bore of the throttle body, and I saw that the throttle body was not set dead on with the opening of the intake, so I carved away some meat around the opening of the intake and I also increased the upper curve clearence (i hope that makes sense).
Next I flipped the top manifold over to check out the 6 holes that allow air to flow into the middle manifold, the inside of the tunnel is about 1 1/8", but the holes are only 1"!! So I opened the holes on both manifolds to match the size of the tunnels. This should help somewhat.
I also smoothed the curve that comes before the hole. (Not very technical am i? lol!)
Here are some pictures, please note that I am not finished, i have some cleanup to do on them.
Hole BEFORE port job
Hole AFTER port job
comparing the holes before and after
Also please note that you can only take off meat from one side of the hole, it's the only side that will make a difference. Look at the pencil markings to see which side i mean. Also, you can only take off so much before it just wont make any difference. I opened them up only enough to match the tunnels.
I used a dremil and some cutters for this job. If you have access to a mill, MILL them instead for better results. I should have used the mill at work didnt think about it till it's too late.
Old Jan 11, 2004 | 03:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
OK looking at the engine from the front.
Did ya notice its like they only made a gasket for the right side and then just flips it over for the other side.
And it doesn't really fit right. On mine the left side gasket hung into the port a good 1/8-1/4 in.
Old Jan 11, 2004 | 07:49 PM
Car: 88 Camaro
Engine: 310 LG4
Yeah i did notice that, damn GM engineers!! I'm just goign to cut mine with a razor blade to match the new ports. they are still in great condition.
Old Jan 11, 2004 | 10:21 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
use the dremel on the gaskets too...that's what i did.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
