coolent temp sensor
Old Jan 22, 2004 | 05:00 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
coolent temp sensor
Is there one or two? Where is it, or they, located?
Old Jan 22, 2004 | 05:20 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
there are 2 one on drivers side head, for the temp guage
other on pass block? I think for the ECM.
XSVortex's Avatar
My 85' has the temp sensor on the front of the manifold, and im almost positive it only has one. There is also a fan switch and some other sensors, but only one actual temp sensor. Try taking it out and cleaning off the tip of the temp sensor if it has any corrosion on it... mine was a little gummed up, I took a wire wheel to it and now it works fine (Auto Zone and Kragen didnt carry it).
Old Jan 22, 2004 | 05:31 PM
V6sucker's Avatar
Engine: blown up
you have a 85-89 90-up is different I believe.
Old Jan 22, 2004 | 05:45 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
OK, just looked atht eengien (not gonna happen after 31 Jan) 1 sensor by the thermostat (beside the sensor for the csv for those that have it), one in the front of the driver side head. Thermostat one is most likely for ecm, & head for gauge.
The fan switch is caddy corner from the drivers head in the rear of the pass head.
Old Jan 22, 2004 | 09:11 PM
V6sucker's Avatar
Engine: blown up
knew there was 2 but forgot where the second one was... I was thinking the fan switch as the other temp...
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
