3.1 struggling a bit
Old Jan 22, 2004 | 06:42 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
minor problem with my new 3.1, everytime i slow to a stop the rpms drop from normal idle to like 400 and 500 and jump up and down from there to 1000. any ideas what might cause this, usually doesnt do it when in neutral and every now and then the rpms drop to low and it dies. little help?
Old Jan 22, 2004 | 07:56 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Well don't quote me, but I did read in another post that the drop in rpm is a symptom of a bad fuel pressure regulator. Do a search. I believe that the jump in rpm is just the computer trying to recover the engine idle speed.
Old Jan 22, 2004 | 08:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 3.1 struggling a bit
I would do an idle learn procedure on it. With the new engine I take it that the battery was disconnected? The 3.1's w/auto's need to learn how to idle whenever the ECM loses battery power.
Here is a link to the procedure:
https://www.thirdgen.org/techbb2/sho...idle+AND+learn
RBob.
Old Jan 22, 2004 | 08:10 PM
Well, I learned something new today (even though I don't drive an auto).
F-body-fan
Jan 12, 2023 01:49 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
paul_huryk
Oct 1, 2015 04:27 PM
Zell1luk
Sep 29, 2015 10:36 AM
ndndndnd
Sep 28, 2015 08:00 AM
