lets see em, lowered 6s
Old Jan 27, 2004 | 07:14 PM
92RSMuscle's Avatar
lets see em, lowered 6's. im thinking about it, but i wanna see bout clearance issues
mike
Old Jan 27, 2004 | 08:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I've been trying to get others to post their pictures. No luck yet.
Old Jan 27, 2004 | 09:34 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
looking At my car i dont see how it could go much lower. My y pipe is like 3 inches from the ground now. Id take a pic but we have 6 inches of snow now.
Old Jan 28, 2004 | 12:25 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
my car is stock height now, but my sig has a pic of it before the new springs.
by the way, this low had MAJOR clearence issues, the frame/ypipe/oil pan/tranny hit the ground ALOT. hard a couple times, not worth it, dont drop more then an inch
Old Jan 28, 2004 | 02:23 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
i WILL POST PICS FRIDAY WHEN I GET MY CAR WASHED.
Old Jan 28, 2004 | 03:25 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
as soon as i get near a digital camera and somewhere that doesnt have over a foot of snow, ill post pics of mine.
Old Jan 28, 2004 | 06:42 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Currently has a botched spring cut or torch job done by a prior owner- rides like pooh. I have Eibach Sportlines and new KYB's waiting to go in when I get a weekend.
Eric
Old Jan 29, 2004 | 01:03 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
I am very interested in this thread..... when you post a picture please list what springs as well as shocks/struts you have, along with if you had to cut a coil or anything like that. thanks
Old Jan 29, 2004 | 07:14 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
My car with Eibach Pro kit, and kyb suspension. Horrible picture, but it'll do, im not exactly sure how much it lowered it, i think about 3/4". I already have to go up driveways at a super steep angle, plus my exhuast/cat is really close to the ground. i wouldnt lower it more than a inch, or you'll be scraping all the time, and will probably bottom out hard a few times at least.
Old Jan 29, 2004 | 07:18 PM
84Berlinetta3rd's Avatar
Car: 84 Berlinetta
Engine: LC1 V6
Transmission: 5 Speed
I just put in ST's from Suspension Max and struts/shocks from Monroe. Gas charged rear and what ever for the front. I got them NEW in the box off eBay for $60 delivered (GF crashed the car before he could install them).
The springs gave me 1.25" drop all the way around. I don't scrape anything unless I aim for it!
http://www.suspensionmax.com/SPRINGTECH_COILS.htm
Old Jan 30, 2004 | 12:24 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
84Berlinetta3rd check that rear tire's rotation arrow I think you have it mounted wrong or you rotated the wheel to the wrong side of the car.
Old Jan 30, 2004 | 12:51 AM
FAST RS's Avatar
my camaro looks soo much lower then that i will take pics tommorw like i said but my wheeles are very low yes it loks good but i dont like being soo low.
Old Jan 30, 2004 | 01:12 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
84Berlinetta3rd
car looks to have the same amount of space mine does. Maybe since it all new the shocks n struts are holding it up higher?
I actually have coil over shocks on the back of mine. The coil overs were installed unloaded to give no lift but I stuck 1 1/2 in lift studs on to the shock to even out the ride.
So I'm "lifted" but only so it was even all aorund. Car rides and handles nice.
Old Jan 30, 2004 | 07:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I posted this before/after shot a while ago after I did my swap, here they are again!
Oops, almost forgot- the springs are Suspension Techniques V6 springs, part # 60115, from www.shox.com.
Extra things changed at the same time: KYB GR-2 struts, KYB Gas-A-Just shocks, KYB strut mounts (both sides), ES polygraphite control arm bushings, new Moog tie rod ends (inner & outer)/center link/idler arm/adjuster sleeves/balljoints.
Old Jan 30, 2004 | 07:27 PM
FAST RS's Avatar
I took the pics today i will upload them when i get home. Why does everyones car seem higher then mine??? All i did was a 1 inch drop all around. My shocks ansd struts are in perfect shape.
Old Jan 30, 2004 | 11:22 PM
FAST RS's Avatar
here are pics
Old Jan 30, 2004 | 11:24 PM
FAST RS's Avatar
Wow the camera got the 2 different colors you cant notice it in person unless you really look. heres the back
Old Jan 30, 2004 | 11:29 PM
FAST RS's Avatar
side view
Old Jan 30, 2004 | 11:32 PM
FAST RS's Avatar
front
Old Jan 31, 2004 | 12:39 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
84Berlinetta3rd: Bud Light???
Anyways, mines not lowered yet, but I have a week off in a couple of weeks, and assuming all goes as planned (like finding a spring compressor), I'll be doing my steering/suspension rebuild.
I've got Suspension Techniques springs with Tokico shocks going on, along with new V8 control arms and a lot of other stuff. I've got about $2000 in parts sitting in my closet waiting to be called into active duty.
Old Jan 31, 2004 | 01:35 PM
Xophertony's Avatar
Axle/Gears: n/a
when i lower mine i am going to keep stock in back and lower the front, give it that going fast whil standing still, wish there was a way i could raise the back about a half inch, do blazers use the same size springs as 3rd gens?
Old Jan 31, 2004 | 03:17 PM
92RSMuscle's Avatar
gabrial makes air shocks for thirdgens for the rears, thatll raise it
Old Jan 31, 2004 | 03:27 PM
If you want to raise the rear, get new spring isolators from GM. They're not the original 3rd gen ones, they are 4th gen ones, and they will add about 1" of lift is what I've heard. I've got a set of 2 that I'm not going to use if you want them.
Old Jan 31, 2004 | 07:02 PM
Car: 3
Engine: inboard
No, Blazers use leafs. I wouldn't raise the back any, lowering the front should give you what you want, unless you want that awful '70's stinkbug stance....yech!
Eric
Old Jan 31, 2004 | 10:17 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
what's with the can under the rear end and the front a arms? lowering springs won't change the height there...that only depends on wheel/tire size. i'll post some pics of mine sometime, it has stock springs but i'm thinkin they may have worn a little over the years, its not bad though.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
