coolent temp sensor question
Old Feb 1, 2004 | 12:05 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
Ok, is there 1 or 2? I get mixed answers, i only can find the one on the intake manifold. Also will putting pipe dope (thread sealer) on there mess anything up?
Old Feb 1, 2004 | 12:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not sure on your car, but it should be similar to the engine on mine. I have a 350 tpi, just below the throttle body is the coolant temp sensor, in the area near the #1 sparkplug is the engine temp sensor for the temperature guage on the instrument panel, near the starter is the temp sensor for the heavy duty fan relay. All three sensors have a different type connector and are not interchangeable. They all come with a thread sealer already applied.
The Trickster!!!!!!!!!!!!
Old Feb 1, 2004 | 12:44 PM
Transmission: autos
ok thats what i needed to know, the one below the thorttle body is the one that sends the info to the ecm right? It doesnt look like it has thread sealer on it Wont hurt to put some on it will it?
Old Feb 1, 2004 | 12:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: coolent temp sensor question
On your '91 there are two coolant sensors. The one in the front center (under TB) of the intake manifold is a two wire unit for use by the ECM. Can dope it up all you want.
The gauge sensor is located in the front corner of the drivers side head. Sticks out at an angle and can be seen behind the A/C compressor. This is a one wire sensor and needs to be grounded to the head.
Fan is ECM controlled and has no sensor of it's own.
RBob.
Old Feb 1, 2004 | 12:54 PM
Transmission: autos
Ok so since my guage works the #2 one isnt bad. But i dont even know if #1 is bad but i heard it wont throw a code and im well on my way to replacing every sensor for the engine
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
squiggy2
Aug 9, 2015 09:30 PM
