Miles
Old Jan 30, 2004 | 04:41 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Miles
Ho wmany mile sahve you guys put on 2.8s. I have 128,00 on mine. How long do you think it will go until. Whats the most you have ever heard of? Thanks
Old Jan 30, 2004 | 05:42 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
well, I got a 3.1, but its around 200k.
I belive tomp has the most miles on this board.
Old Jan 30, 2004 | 05:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
While picking up the sticker for my plates today
[ It my B-day today, no applause plz]
I notice I had exactly 214,000 miles on the clock.
Got it around 168,000, put in a new T5 at 204,000
Old Jan 30, 2004 | 08:25 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Mine have 114 500 miles with original engine and transmission
Old Jan 30, 2004 | 09:05 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
123,800 on a 3.1L
Old Jan 30, 2004 | 09:06 PM
Jeffs RS's Avatar
Car: 1988 Camaro RS
Engine: 2.8L MPFI
Transmission: 5-Speed
223,000 original miles, and still getting 30 miles/gallon total freeway driving
Old Jan 30, 2004 | 09:56 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Happy bd G! I have 107k and the rods, lifters and pistons(well the tops is all i could see of the pistons) still look brand new. On a 85 too, i dont think the prev owner drove it very much!
Old Jan 31, 2004 | 05:49 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
i have 136K rebuilt at 110k (acording to prior owner, runs great so i assume he is telling the truth, never seen cleaner oil after 2k then in my car......) Tomp has somthing like 250k on his 2.8L. but that thing is NOT STOCK.
EDIT: happy b-day gumby,my b-day was the 29th. i am 20 now (wow, so much wisdom i hardly know what to do with it )
Old Jan 31, 2004 | 12:28 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I have 155k miles (255k km), allegedly rebuilt somewhere around 125k miles (200k km). Transmission is still original with pita reverse gear.
Old Jan 31, 2004 | 12:32 PM
Slow2.8's Avatar
136,xxx original motor/ trans... still running strong
Old Feb 1, 2004 | 11:45 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
199,430 on my carb'd 2.8! Power has gone MIA
Old Feb 1, 2004 | 12:18 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
112k on the 2.8, when a rod bearing went, now about 5500 on the rebuilt 3.1, going great!
Old Feb 3, 2004 | 01:00 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
194,7xx and it has just gone out on me. I'll save it for rebuilding and put it in a different car. I think I am headed for a new 3.4. Trans is still going strong though...
Old Feb 3, 2004 | 12:34 PM
Engine: 2.8 Lt
Transmission: 5 Spd
How did it die?
Old Feb 3, 2004 | 02:52 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Bad evap can+good vacuum lines+gas flowing through the vacuum system and getting in the cylinders, creating extra puddles of gas. Turn engine, get nothing but a lot of sputtering. Let it sit, gas gets in oil. Turn engine over, kiss bearings goodbye.
The equation when I got the car was:
bad evap can+crappy junk vac lines=air in the vac lines instead of gas. Engine gets hot, it stalls when braking due to excess air. Did not notice bad evap can until new vac lines went in over the summer, ALL of them. Ran great though, with dark oil. change oil to wrong weight (how was I supposed to know? High performance engine, high performance oil, right? No manual either) and lifters start making noise. It went to hell from there...
Old Feb 3, 2004 | 05:54 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
You guys are not going to believe this, but I just got off of another forum that I frequent and was talking with a moderator who had an old Chevy s10 Blazer with the carbureted 2.8 who said that he had +400K ORIGINAL miles on the ORIGINAL motor when the camshaft finally "flattened out" and the motor died. Granted, that's not the VIN 1 F-body engine (I think the Blazer had a VIN B), but they're essentially the same thing. The guy said his dad bought it brand new and took religious care of it, and then the guy inherited it at about 250K and put the remainder of the 400K on it himself, taking the same care of it as his father did.
My Camaro (1984) has about 140K on it right now, still running good. Of course, I won't end up getting 400K on it with the way I drive...
Old Feb 3, 2004 | 06:56 PM
KED85's Avatar
My 1985 Balzer 2.8 had 211,500 when it died.
Now it's also 3.4 powered.
What year was that Blazer & was truck a 49 state vehcile (not residing in California)?
Old Feb 3, 2004 | 08:52 PM
Car: 1984 Camaro
I think it was a Virginia vehicle, would have been right around the same year as yours. I'd have to ask the guy to be sure.
Old Feb 4, 2004 | 01:14 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
im at 230,xxx 91 rs 3.1
Karl i got rid of the block set it out on the sidewalk with crank and all damaged parts ecept the heads and old tranny. was gone in less then a day.
Old Feb 4, 2004 | 03:06 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep scrapers are everywhere. Never leave anything you want outside over night, they will take that too.
No to stereotype anyone but most scrapers around me are two guys in an old truck who's whole living is made off of scraping.
So anything made of metal in sight is taken. They mostly do it while people are asleep or at work. I never see them but see them near the scrap yard full of junk all the time.
Buddy lost a fridge full of beer like that. It was on the back porch when he went to sleep, it was gone in the morning.
Old Feb 4, 2004 | 03:14 AM
FAST RS's Avatar
I left it out there for them to take. When we got a new washer and dryer we went to grab lunch and came back and the old washer and dryer were allready gone. Last week i was cleaning the grague there was allot of crap i had no use for so i put it on a pallet for them and they took it all the damn thing was packed.
Old Feb 4, 2004 | 10:01 AM
KED85's Avatar
WAY TO GO!
Be THANKFUL no neighbor called LA County on ya.
Be saying Hi soon, still doing stuff until I leave for Phoenix real soon.
Hold onto heads & tranny I have a plan.....
Old Feb 4, 2004 | 10:33 AM
FAST RS's Avatar
K I ALSO HAVE THE NUMBER MATCHING EXHAUST MNAFOLDS FOR THE HEADS I JSUT WANA DUMP BOTH OF THEM FOR 100 BUCKS.
Old Feb 6, 2004 | 08:33 AM
WaynesRS's Avatar
88 rs camaro - I got 170k miles out of original motor
200k miles when I traded it in
I MISS IT BAD GUYS !!! I really do
98 silver t-top camaro - 59,000 when bought (oct)
68,000 on it now
I think I get the award for piling the most miles on a car in four months !
HOW HAVE YOU GUYS BEEN ?
Im ganna try to start roaming around here sometimes to help you guys out ! All the help ya'll gave me in the past , I want to give it back ! :-)
p.s. You guys dont ever complain about changing plugs and wires on your third gens , these 4th gens are a bitc* My hands are so beat up from changing them !!!
Old Feb 6, 2004 | 02:06 PM
Car: 1984 Camaro
ha ha, yeah I've heard the fourth-gen's are REAL fun to change the plugs on, even with the V6. Of course, I wouldn't expect it to be a breeze with the motor halfway under the windshield...
Old Feb 8, 2004 | 03:37 AM
nadster's Avatar
Car: 89 RS
Engine: 2.8 (the cruiser)
Transmission: 700R4 (TransGo Kit, VetteServo)
143k/mi on my 89 t-top RS right now. She's spending most of the time in the garage at the moment awaiting for me to get enough money for a trans rebuild and a new trans cooler.
-Dan
dbrochard
Oct 3, 2015 12:43 PM
Nick McCardle
Sep 10, 2015 08:36 PM
84 TA NV
Sep 6, 2015 08:02 PM
tgp1990
Sep 4, 2015 06:24 AM
