V6 sway bars vs. iroc sway bars
Old Feb 6, 2004 | 01:35 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
As you may know from one of my other posts, I got a set of iroc sway bars from the junkyard. The problem is, when I was taking my original ones off, 3 of the four outside bolts snapped off b/c of rust, etc. I probably should have heated them up a bit but didnt think of it till it was too late.
Anyway, I need a new set of bolts for the front and back and new (rubber, polyurethane, or whatever they are) bushings for the sway bars b/c the originals are pretty beat. Does anyone know if the front bolts are different than the back ones? Are iroc bolts different than v6 ones? Do they make kits or something that would have the bolts and bushing together? What would you recommend?
Old Feb 6, 2004 | 01:48 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I installed the same bolts/bushings from ES front and rear.
Old Feb 6, 2004 | 09:14 PM
Xceleratemaro's Avatar
its a 34mm (more than likely) i would go with poly bushings.. for the endlinks.. you can pick them up at any advanced and auto zone.
Old Feb 7, 2004 | 12:24 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
wow, man.. they snapped for you? you're lucky.. i tend to have to cut my OE ones off.
As the people say.. just about any local parts store.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
mustangman65_79
Aug 11, 2015 03:17 PM
