No start
Old Feb 13, 2004 | 01:00 PM
jeremy178's Avatar
Car: '89 Camaro RS
No start
See if you guys can help me figure this one out. I've got an '89 RS w/ a 2.8 that won't start. When I pulled it in, it was running crappy, then I shut it off and a few days later now it won't start. I've checked the ICM, ECM, Dist. cap, wires, plugs, rotor button, pickup coil, ign. coil (the spark is good). It hasn't jumped time, ign. timing is right on, it's getting fuel, has 45 psi w/ key on. When I try to start it, it just acts like it almost wants to start, and I can hear it popping through the pipes. The only thing that even seems out of the ordinary is that after I try to start it, the fuel pump stays on about 10 seconds, and I can hear what sounds like a leak coming from the fuel rail. It's not leaking any gas on top of the motor, could it be faulty injectors? I put them in not too long ago. Any advice would be appreciated. Thanks
Old Feb 13, 2004 | 03:25 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
did you check for spark
Old Feb 13, 2004 | 09:30 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
it could be you distributor $hitted out on you
That what happened to me.
That was funbo
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
