You guys are gonna love this!
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Well i thought i had an exauhst leak so i was messing with my car today. I stuck a hose in the pcv hole with the motor running and the ticking got louder. So i took the pass side valve cover off and looked at the rocker arms, the rear most one was a little loose, so i turned and still loose , turn and turn and turn and it got tight BUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! the nut is along way down the bolt. WAY more than the others. COllapsed lifter? correct?
Car runs fine just has the tap tap tap tap that cant be heard when driving, only at idle.
Now im getting a 3.4 for the car this summer SO i really dont want to put a cam and lifter set in it.
What would you do?
BTW did i mention how much 2.8's SUCK!!!!!???
What would you do?
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
yeah, I thought I had an exhaust leak on the passenger side, so i replaced all of the gaskets over there, but still had my tick. I have come to the conclusion that it is a collapsed lifter. I am going to be getting a 3.4 in the fall, so i think I'll just suck it up and run the car as-is, if it dies, then the 3.4 will be coming sooner than later.
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I had to replace 3 of my lifters with 138k on the 2.8 because they were sticking. Found it out when I replaced the head gaskets (just for fun) and found that the rods would go down but not back up again. If this is the problem, find some good used lifters because new ones are about 20-50 bucks a piece. I don't remember how many I replaced, but it was expensive. Now that I've got tons of V6 parts at my house, I'll never buy another lifter.
Car: 85 firebird
dude autozone has the lifters for $5 each, you got screwed. As doward said you cam get a cam and lifter kit for a little over $100.
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
that is sucky. your always gonna have problems with you car. it comes with type of car you have
Car: 85 firebird
So far things that have went wrong.....
Coil went out on me while my girlfriend and i were at the movies 30 miles from home price for repair = $90 tow home coil was free , i had a old one from my mustang in the closet, i wired it to work with the 2.8.
Head gasket went out on xmas night i was like 2 mins from my house so i went home....Price=$60 had to do it in the cold weather here in the snow most of the time..
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
$20-50 for a lifter is nuts.. even the hydraulic rollers for my V8 are only 9.79 each.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I've got some lifters, rocker nuts, studs, even some rockers. You need some, PM me, they will be cheap
Limited time only though, scrap yard is coming soon.
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Well big one
Distributor Had to be replaced
coil died
wires went bad
headlights died after one melted the wires
the o2 sensor
the altonator went bad
i could go on and on
but i wont
coil died
wires went bad
the o2 sensor
but i wont
ambainb
Apr 25, 2016 09:21 PM
