performance distributor parts
Old Feb 16, 2004 | 07:13 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well guys i;m curious what all you v6 guys are running for distributor caps and rotors
mines stock and i'm looking to upgrade
Old Feb 16, 2004 | 07:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Accel #8133 cap/rotor set... tried to go back to stock Ac/Delco but the MSD ignition destroyed it! So I'm back with brass. http://www.geocities.com/tomp_3rdgen/burnt-cap.html Use summitracing.com part # ACC-8133 ...
Old Feb 16, 2004 | 07:32 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
whatever brass one the parts stores hand me. For some reason my system wears thru them in about 2 oil changes.
Old Feb 16, 2004 | 07:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Might wanna check you cap index. You car can be in proper "time" but your cap index could be off, wearing them out much faster.
Old Feb 16, 2004 | 08:01 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
hmm i've heard bad things about accel how its worked for you?
Old Feb 16, 2004 | 08:04 PM
Dale's Avatar
Engine: 350 S-TPI
gumby, are you refuing to the center terminal?
How would you go about adjusting the cap? It is held in place with ridges, and cant move.
How would you plug the hole back up that you drilled to check whatever.
BTW, I have replaced the whole distributor, both have done this, along with changing coils, wires, icms..
86IROC112
Aug 17, 2015 07:57 PM
86IROC112
Aug 17, 2015 02:00 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
