Double Grounding the Coil
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i don't kow if it'll help but it won't hurt. if, for some reason, you have a slight ground issue between your coil bracket and block (head), then you run a ground wire (FROM the coil mounting holes) to another ground sourch, you'd be fine.
Glowsock
Sep 5, 2015 07:48 PM
