Help!!!!!
Old Feb 28, 2004 | 04:23 PM
GTABABE's Avatar
Car: 87 GTA, 85 Iroc-Z, 92 Camaro RS
Engine: 350, 350, 3.1 V6
Transmission: 700r4, 700r4, 700r4
Help!!!!!
I need to know why this part will not spin for a while when i start the car. After a while it will start to spin and make a clicking sound. Also after i turn off the car i hear a hissing sound. Help Me Please. I know this may not be a RS but that is what i have and this is the only pic of a bay i have right now. Sorry the pic is bad
Old Feb 28, 2004 | 06:18 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
rip it out and throw it away
Old Feb 28, 2004 | 06:21 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
lol.. uhm.. your car is fine.. A/C compressors are clutched and don't run at all times.. try turning your A/C off and notice that it never starts spinning and the clicking is entirely gone.
Old Feb 28, 2004 | 07:13 PM
BitchinRS's Avatar
Is the hiss only heard inside the car? If it is the it's because you haven't set the climt controlls to the "off" position (all the way to the left). They are vaccum (SP?) controlled and when there is even the slightest leak they will hiss.
Old Feb 28, 2004 | 07:28 PM
GTABABE's Avatar
Thanks for the tip I am new at the whole thirdgen thing and as you could probably tell from my name i am a girl. But that doesn't mean i don't know much about cars. I am just good at fixing things not knowing what is wrong with them to begin with. :lala:
Old Feb 28, 2004 | 09:16 PM
Aqua FBody's Avatar
Car: 95 Contour GL 03 KIA Spectra
Engine: 2.0 Zetec 1.8
Transmission: MTX-75 5spd
Can't see from the pic is that the AC compresser if it is do what I did and take it out
Old Feb 28, 2004 | 09:30 PM
GTABABE's Avatar
maybe this is a better pic
Old Feb 28, 2004 | 11:43 PM
KED85's Avatar
YEP AC Compressor
And it cycles on & off & yep the hissing is from the HVAC control setting not in a certain position.
Normal what happens if ya not shut off the AC system in your car.
Old Feb 29, 2004 | 01:08 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Here's what you do.
(although stated above)...
Turn the car on, turn on the A/c (on cold). Open the hood And watch the compressor. If it spins, stops, spins stops, it's just low on freon. It'll probably still blow cold though. The hissing sound you here when you turn off the motor is pressure equalizing in the A/C system (by way of an "expansion valve"). It is completely normal. Good luck, enjoy the A/c
Old Feb 29, 2004 | 09:22 AM
GTABABE's Avatar
Thanks alot guys
