Strange Wire?
Old Mar 6, 2004 | 09:23 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Strange Wire?
I recently got my car back from the shop, so today i decided i would spend a little tim working on some stuff. I looked under the car while it was in the sir and in front of the tranny on the drivers side there was a black wire with a round hook on it (belive it is a ground) The wire comes out of the harness itself. I cannot see where this would even plug in, any ideas? Thanks
Old Mar 6, 2004 | 11:04 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Don't quote me, but that's about where the oil pressure switch is, so maybe that is unplugged.
Old Mar 7, 2004 | 03:10 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah but my switch works inside the car which is wierd if that was unplugged. Would it still work like that? Thanks
Old Mar 7, 2004 | 03:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Does it go to a ring terminal? I think there might be a ground going to the rear of the driver's side head; there should be a bolt (or by now, an empty hole!) in the back of the driver's side head for a ground.
Old Mar 7, 2004 | 07:15 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Yes, it has a round ring hole on it like you said. I just had the y-pipe dounuts did so that would make since. Now where does this exactly go to? I was looking today and couldn't find where it went to. What is the ground for? Thanks
Old Mar 8, 2004 | 10:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It should go (as I said) to a bolt that would be in the rear of the driver's side head. But if they didn't put the bolt back, there will just be an empty bolt hole.
Not sure what it grounds to, sorry... I used to know, but it's been a lonnnng time since I was back there! The ground on the back of the passenger side head (also black wires going to a ring terminal) is for the computer and it's sensors- there's a junction point midway up the wireloom that's strung along the passenger side's strut tower. A bunch of grounds tie into that junction, then one wire goes up to the rear of the passenger side head.
As to what's connected to the driver's side head, I can't remember... sorry!
Infested
May 22, 2018 11:56 PM
someone972
Aug 30, 2015 12:52 AM
red90IROCls1
Aug 25, 2015 06:56 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
