V6 GM part numbers
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
V6 GM part numbers
Does anyone know the difference between the different 2.8L blocks that GM produced? I have 2 blocks sitting at home with different numbers spread in different spots on the block. One block has a mechanical fuel pump, one doesn't. Both have a two piece front bearing with the chain cover that bolts to the oil pan. Are these 1st gen crap blocks? The rear of the crank is larger (74mm?) which I assumed made them 2nd gen blocks. I would really like to hear that someone has some actual numbers to look for. Both blocks say 2.8 C, or G, on them, but its hard to tell. Both are out of 86-87 year cars. Anybody know?
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
sorry don't have numbers or anything, but the mechanical fuel pump should be a dead give away for a carbed engine, atleast in all my experiences.
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
agreed mech. pump would mean carb motor.
sure ones not out of a s10?
never knew they had carbed 2.8 in thirdgens just throttle body and multi ports.
were as our s10 has throttle body and my friends old model s10 had a one barrel carb on it.
we used to have a chilton manual had engine sizes try them or search for engine id numbers on the net.
i know jegs n summit sales engine id number books for small blocks but nto sure on v6 or maybe yur local gm dealer could help if ya called n give em the numbers they should be able to reference them for u
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I can get you short block numbers, but not physical block numbers
If one has fuel pump mount, and the other block has same size crank, then it is of same crank/block style.
The larger crank was used on 87/88+ style engines.
Might be better off trying to find a s10 2.8 block. And had I known you needed a block, I would have sent that to you also. But you would have had to pay for shipping :P
Remember, dont use the heads off the carb engine!!
Engine: 350 S-TPI
benoit454, v6 thirdgens NEVER got TBI engines, they did have carb 2.8 from 82-84. Then went to mpfi in 85.
Car: 1989 RS
One of the blocks came from a Camaro, the other one from a Jeep. The Jeep crank is spun anyway, but it is identical to the Camaro block. The heads seem to be the larger 2nd gen style, and both have a solid rear bearing. I'll try to call the dealer to see if I can get some numbers.
Car: 86 camaro
if they didnt have tbi on the 2.8 camaros then what camaros did they put it on the 305?
because theres a special section on here for tbi ones.
instead of tuned port or multi port.
and i also wondering if hed had one fomr another vehicle n all so thats why i stated that about the tbi unit
Car: 86 camaro
as many ppl that swap engines there proly alot runing round place w/ tbi on v6s or v8s
must be the v8 im thinkin of that had the tbi tho thought it may went for v6's
im nto a v6 man more of a v8 only v6s i dealt w/ in my life is one im my car and the s10's
Car: 1989 RS
Nobody has solid numbers as to what the difference is or how to tell the difference? Please stay on subject.
Car: 86 camaro
we are staying on subject blue.
i wished i knew on v6's because the chilton manual we had u looked up the i.d number on the block flat spot right on the pass. side under the alternator.
this was for a v8 we done.
and the book told u as to the engine size torque specs, bore storke displacment, horsepower and torque from the factory.
my dad was one looked it up im thinkin he might have started by what year it was but im not sure its ben awhile.
would that be what yur lookin to find out?
all the specs of it and stuff and what year it came out of?
id definatly try a search for the number on the block itself.
not sure were they are on v6 i was goin to say on the front type in like 2.8 v6 then the number u know or different variations of it on yaho or somethgin n try find it there.
if not id call up gm or yur local auto parts stores n ask them what u need to know or about an engine numbers id book
Car: 1989 RS
The only thing that I saw on the pass side was the letter "L" in the back and then the "2.8 C" marking under the alternator.
I just called the Chevy Dealer here in town, and he said that the block cast numbers are not the GM number. Those numbers are the manufacturers specific numbers. From there, GM uses those numbers in reference to another book somewhere. So a number for a number. I'll get to the bottom of this eventually.
I had not intended to be rude. I'm just searching for some
Engine: 350 S-TPI
The engine i just installed I belive had the orignal cars vin number on it
Didnt even pay attention to the old block
Car: 1989 RS
I'll see if the guys at....dare I say it......60*V6 have any suggestions.
I did contact Chevy (1800-222-1020), in particular, Synthia Slat (sounded hot!) She said that she'd look up the numbers for me. So anyone else have an easy way to tell what I've got?
Car: 86 camaro
man thats a toughy lol.
gotta watch them chicks sound hot on phone in person they usually dogs lol trust me i found out the hard way a few times lol.
i have no clue were to find it id try search for v6 id numbers matter fact ill search here ina few to see what i can come up w/ and pm ya w/ any info man hope i can find somethgin to help
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep yep yep, if they sound like a bull moose on the phone she is hot, if she is melting your pants over the phone well, SHES FAT.
Its so true its unreal. And trust me you do not want to find out your self. Trust us.
Car: 1989 RS
Oh trust me I know. Same thing happened at my old work. Receptionist could just about melt you over the phone. See her in person and
...WTF? I think she ate the hot chick and stole her voice LOL!!
She said she would help though. So when I get home tonight I have to write down some numbers. I know on my block in my 89, there is an 8 digit number above the water pump. I'll have to check the other blocks as well and give her all 3 or call dealer back and see what they can tell me. I'll be sure to post them. Thanks for your help on this! Someone should sticky this useful information somewhere.
...WTF? I think she ate the hot chick and stole her voice LOL!!She said she would help though. So when I get home tonight I have to write down some numbers. I know on my block in my 89, there is an 8 digit number above the water pump. I'll have to check the other blocks as well and give her all 3 or call dealer back and see what they can tell me. I'll be sure to post them. Thanks for your help on this! Someone should sticky this useful information somewhere.
Car: 86 camaro
man i was thinkin the same if someone could find some engine id numbers or links they should make a sticky even for v8s it would help out alot.
esp oen liek in that book i had it posted main and rod and head torque specs factory hp and ft lbs and all that stuff was really helpful we could use it for v6's too.
1992 Trans Am
May 10, 2023 07:19 PM
IrocZ'85
Aug 17, 2015 06:24 PM
