Need advice on power window problem
Old Mar 19, 2004 | 04:22 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I was coming home today and the passenger side window did'nt work.The left side seems to come down ok.I don't think it would be the fuse since the left side is working.I'm thinking it might be the power window motor has gone out.I can hear the clicking of the contacts or actuator as I press the passenger side button located in the center console.What do you guys think?
-Ken
Old Mar 19, 2004 | 07:35 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
possibly could be your switch, if you can hear the actuator starting or engaging but the window isn't moving at all, there's a chance that the switch isn't making a good connection. Cheap check, pop the switch out, take the hot wire, and bridge the gab between the ground wire w/ a paperclip, (it'll spark , so don't get scared) if the window moves some, then you know that your switch is bad, so go ot the yards and see what you can find, or replace it w/ aftermarket or GM parts if ya feel like spending the $$. If that's not your problem, itd most likely be your motor, but, that'd be the cheapest test i can think of.
Old Mar 19, 2004 | 11:05 PM
Ovrclck350's Avatar
Or if you don't feel like using paper clips (dont' worry though I had to use paper clips for ~2 months on my convertible) then just use your other switch.
Old Mar 22, 2004 | 08:13 PM
ken3983's Avatar
Ohh what a relief it is.......it seems it was the switch had went bad.So I decided to make a junkyard run to get one and some other goodies while I was out and about.Luckily, it was'nt the motor...but hey, the thing is 13 years old.It would'nt have surprised me if it was the motor.Thanks for the help guys.
-Ken
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
