Check engine light no worky
Old Mar 24, 2004 | 09:57 PM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
I've swapped an '87 MPFI 2.8 into an '85 Cherokee. I'm trying to find the reason for the coppy, rough idle. I wired up a light to the wires for the check engine light to check codes, but get no power to it. The manual I have shows the check engine light wire to be a brown with a white tracer. I wired a light to that wire and the other end to chassis ground and get nothing. Is there a wire connetion to a certain componant of a MPFI system thatt'l effect this? Any ideas, thoughts???
Old Mar 25, 2004 | 04:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did you use a computer-safe probe? I've never looked at the wiring diagram for the SES light- I don't know if it can drive a bulb directly, it might draw too much power from the computer.
I'll try to remember to check tonight!
Old Mar 25, 2004 | 06:01 PM
CHVYPWR's Avatar
The wire that I'm connecting the test light to is the one on the harness plug that plugs into the back of the inst. cluster. My test light is a home made one using the same type of bulb that is in the dash for the check engine light.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
