Whats Left?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Whats Left?
ok, heres me setup. Respond with any other engine goodies I dont have listed keeping engine n/a, and with-out pulling it again........
HAVE
L32 (3.4) block swap
Polished heads (not ported)
3 Angle Valve Job
Crane 99915 Retainers
Crane 99848 Springs
Positive Seals On All Valves
LB8 Air Intake (removed deflectors)
Strait Pipe Replaced Wrinkle Tube
Polished Intake Inside
16pph ford injectors (installed during my running rich issues)
Brass Freeze Plugs
Brass Cap/Rotor
Taylor 8mm Plug Wires
Accell 140011 Coil
Cardone 30-1633 Distrib
ASP Dual Pully Set
Dual V8 Electric Fans
180 T-stat
High Volume Fuel Pump
Dynomax 17493 Exhaust
TB Bypass Hard Plummed
ES Poly Trans Mount
Fiero Valve Covers
Removed EGR
Smog Removed
1.6 roller TIP Rockers (ordered)
Whats left I can think of
Proper Port/Polish
Larger Valves
Cam (dowards mtc-5)
FDP TB
Cloyes TC
swap to full roller rockers
AFPR
Headers/y-pipe (waiting
Larger Injectors
Proper Burned Chip
transmission goodies (boost valve, transgo)
HAVE
3 Angle Valve Job
Crane 99848 Springs
Brass Freeze Plugs
Brass Cap/Rotor
Accell 140011 Coil
ASP Dual Pully Set
180 T-stat
ES Poly Trans Mount
Fiero Valve Covers
Removed EGR
Smog Removed
Proper Port/Polish
Larger Valves
Cam (dowards mtc-5)
FDP TB
Cloyes TC
AFPR
)Larger Injectors
Proper Burned Chip
Car: 1986 Firebird
Engine: 2.8 V6
An MSD 6AL box with a 2-stage RPM switch, with a 2500 RPM module and a 5800 RPM module? So you can stage with the gas pedal floored and light brake pedal at 2500 RPM, then when the green drops, click the switch to use the 5800 RPM module and you're off like a shot! Oh, wait, that's my dream... sorry!
There's always a remote water pump... if you've got $300 to spend at http://www.meziere.com
What fuel pump did you install? Did you re-use the pulsator or did you just use a section of high-pressure hose?
Engine: 350 S-TPI
Thanks tom, I autocross, not drag though
Hum, waterpump, that might have to go at the bottom of the list, but its another part too.
I used the 92 350 "stock" replacement fuel pump. Whats the pulsator? If its that thing on the fuel line by the intake, I replaced the whole tube with one from 2.8 that didnt have one.
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
The cam for you
A Baja Beast cam from Crower, I had one description that said it had the normal low end and had a Vtec feeling higher in the band. Sounds nice for Autocrossing. Also, get the transmission goodies installed ASAP, you'll LOVE what it can do for you, it's one of the best mods for anyone, period. The hedders are a definate, dumps would go nice with them, make as much power up top as possible.
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
a 3.4, with the MTC-5 cam, and 1.6 FULL rollers, combined with a good set of headers/y pipe, and catback... oh man. It's going to pull, and pull HARD from 2000-5800 rpm!
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Originally posted by eric17422001
powdercoated by AIM91.
Eric
Eric
shortly, i plan to start ceramic coating too, not just powder coating. Thread
