died on the highway, fuel pump question
Old Apr 11, 2004 | 09:21 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i was coming back up to school today and my car was bucking every once in a while. it would only do it once, the tach would bounce, then it would be fine for like 5 or 10 miles. i hit the on ramp for the next highway and it died. i thought maybe my fuel gauge died, so i got gas in it, nothing. just cranks. i wasnt able to work on it, so i had to have it towed to a shop(every mechanic's nightmare, having someone else work on their car). if it turns out to be a fuel pump, im gonna have an LT1 fuel pump put in, is there a certain one that will work or just any fuel pump out of an LT1 car?
Old Apr 11, 2004 | 09:56 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I would suggest
Get a good NEW Carter unit to put in there. There's no need for a pump out of an Lt1. The Carter unit will provide full flow up to 60 psi (with more lph than you'll ever need). The unit fo the 2.8 part number is P74006. These pumps are bulletproof.
Old Apr 11, 2004 | 10:51 PM
drdave88's Avatar
Engine: 6.0L
sweet, where can i order it from? does summit carry it or is it a special company? if so, how can i contact them?
Old Apr 12, 2004 | 12:38 AM
FbodTrek's Avatar
Hilo
Oreily autoparts. I believe Carter is a division of Federal Mogul, great company, they've been around MANY years. NAPA might carry it too, part number may be diff. though. Just ask for a pump for the PROPER application, then ask them who it is made by.
Old Apr 12, 2004 | 03:22 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: I would suggest
The reason to use the LT1 pump is it is made with better parts. I believe steel instead of plastic. That is why everyone get the LT1 pump. It will last longer and perform better. It will not add any performance, just perform better.
Old Apr 12, 2004 | 12:10 PM
drdave88's Avatar
Engine: 6.0L
does the LT1 fuel pump or any others that i can get from anywhere around have a higher output? i want to get an AFPR to increase my fuel pressure a bit. i dont want to have to wait for one to be ordered. whats the ratings on the V8 fuel pumps compared to the V6 pumps?
Old Apr 13, 2004 | 01:20 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Fbodtrek, would you recommend the Carter over an AC/Delco?
Old Apr 13, 2004 | 01:47 AM
Ovrclck350's Avatar
Screw both and get a Walbro
Old Apr 13, 2004 | 02:43 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The pump will not increase pressure.You have a pressure regulator on your car. Make it adjustable and turn it up. Stock pump runs at 135-140 PSI , car uses 40-45 [something like that, could be off] but you have tons of pressure you can use.
But the better pump is just that, better parts. It may be like 150-160psi cause of better parts but the regulator will not let anymore through then factory settings.
There is an exception. On the NOS system for the 6 It has a return line restrictor that is suppose to work. But I assume it only works as it plugs off the system about 50% which raises pressure so high it makes it bleed more past the regulator.
92camaroJoe
Jul 29, 2023 07:57 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
