Help, cant get my fuel injectors out
Old Apr 13, 2004 | 12:25 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
trying to get te injectors out of my 2.8 but cant figure out how to... i know tehres clips there but how do i get them off?
Old Apr 13, 2004 | 12:33 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
You need to take the upper plenum off, then unbolt the fuel rail, and with a little motivation the thing pops right out. If you want the injectors out of the fuel rail, look at the base of the injector where it meets the rail there is a little like circular clip, find the longest part that is sticking out of the fuel rail and try to move it to the other side of the port. I've found that pliers work best.
Old Apr 13, 2004 | 12:48 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
rotate the clip. Their is a very small "window" where it doesnt grip anything. I use a screw driver on the opposite side of the long "tab", reason I use other side, the screw driver fits perfect into this notch.
Then I grab, wiggle, twist, and pull on the injector.
Watch for flying fuel.
Old Apr 13, 2004 | 03:40 PM
Car: 1986 Camaro SC
i got them out with the fuel rail., all excpet one who was stubborn and stayed in..
Old Apr 13, 2004 | 04:30 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
by the way anyone knows where to buy those clips.I need a couple very bad
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
