Sprucing up a 2.8l
Old Apr 13, 2004 | 06:42 PM
Kilo's Avatar
Car: '89 RS
Engine: 2.8l v6
Transmission: A4
Sprucing up a 2.8l
My '89 RS is mostly stock (the previous owner added a flowmaster, but aside from that nothing major), and I'm wondering about practical suggestions and addons I could get to bring out some more horsepower...it's about 140 right now, and I would like to shoot for an extra 30-40. I'm kinda new to performance parts, and any suggestions will be greatly appreciated.
Old Apr 13, 2004 | 07:18 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
To get that much
You'll need a cam, hedders and some porting work done on the heads. It's hard to squeeze out that much, but it is possible.
Old Apr 13, 2004 | 10:06 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
unless you want to be the one who puts a supercharger on a 2.8....you could get a vortex performance turbo kit when they become available. otherwise, 30-40 hp is not easy to get if you're new to performance parts. the supercharger would have to be all custom though, not too easy to do.
Old Apr 13, 2004 | 10:45 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
some of the easier stuff to do is a 180 or 160 t-stat, underdrive pulley set, ignition upgrades, k&n air filters, cut the bottoms off the air boxes, roller rockers (if you can), dynomax catback, highflow cat or removal of the cat. thats some of the easier stuff to get a few extra hp. you can try cleaning out the carbon too. use some brake cleaner or throttle cleaner. take off the throttle body and clean the crap out of it. then use some GM Top End Cleaner to get the carbon out of the intake, combustion chamber, and off the valves. this will help quite a bit actually. other than that and a couple other minor mods, there isnt much you can do to increase hp without getting into some serious work and $$.
good luck bud!!
Old Apr 14, 2004 | 12:04 AM
camaro_doc's Avatar
other than an intake carb cam headers 1.6 roller rockers you would be getting into some $$. but all is not lost you could rebuild the engine with higher compression pistonsand if you built a solid bottom end you could add a shot of nitrous. You might want to consider geting a lower gear ratio ie 3.73's 4.10's i know that is not engine related but it would give you some extra go. Also you might want to consider getting a turbo or two theres companys out there that make custom setup's for around $300(for just the headers) but that will cost some big bucks. One thing i'msure alot of the guys will agree on though is this statement "Speed cost's money so how fast do you want to go". I hope this helps you out.
Old Apr 14, 2004 | 04:17 PM
Kilo's Avatar
Car: '89 RS
Engine: 2.8l v6
Transmission: A4
Maybe I should just save up and get an LS1 .
Old Apr 14, 2004 | 06:10 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Man no one is gonna talk to you now! You've done it , you've brought up an 8! Jk, Maybe you should go with a 3.4.
bplessy
Sep 30, 2015 12:14 PM
88rscamar0
Sep 23, 2015 09:08 PM
64goatman
Sep 9, 2015 01:09 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
