Taking Out Head Bolts,.
Old Apr 14, 2004 | 02:16 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
they are 15mm right? i cant get any of them to budge, not one, all i have in 15mm is 3/8" drive and i'll just snap those if i put too much pressure on it, so the only real good way to do it is to get a 1/2" drive 15mm socket?
Old Apr 14, 2004 | 02:25 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
yes, you need a 1/2 drive, on a breaker bar. My impact wouldnt even pull them out. I sat on the engine, had someone else hold the engine while I tugged on the breaker bar.
Old Apr 14, 2004 | 02:43 PM
Car: 1986 Camaro SC
yeha, we used a breaker bar on my buddy's 305, but it was 5/8" , none of this mm crap
Old Apr 14, 2004 | 11:10 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
just get a good long 1/2" breaker bar and a 15mm socket and give her hell. just go a half a turn on each bolt to break them loose in the opposite of the tightening sequence. it is possible to warp the head otherwise. its not likely but it can be done if this doesnt happen. once you get a half a turn on each bolt, then you can take them out.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
