v6 HO
Old Apr 13, 2004 | 10:45 PM
Johnnywilde55's Avatar
Car: 87 Iroc, 88 Camaro
Engine: 5.7L TPI, V6
Transmission: 700r-4, t56
v6 HO
i was looking at my cars info using the vin number and it says that the car has a v6 HO now im guess that is high output, did chevy even have a 2.7L v6 HO? and if they did what are the specs on it, would i be right in thinking it would be rare?
Old Apr 13, 2004 | 10:46 PM
srry
srry i ment to type 2.8L v6 HO
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
did you mean 2.8? and as far as i know, there is not HO 2.8. but ive been wrong more than once in my life.
Old Apr 13, 2004 | 10:47 PM
drdave88's Avatar
Engine: 6.0L
oh ok, got that after i posted, lol.
Old Apr 13, 2004 | 10:53 PM
vin results
i have no idea but here are the results from my vin readout
VIN: 1G1FP21******
Year/Make/Model: 1988 CHEVROLET CAMARO
Body Style: Coupe
Engine Type: 2.8L V6 MFI HO OHV
Manufactured In: UNITED STATES
Old Apr 13, 2004 | 11:03 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Thirdgen.org's vin decoder may have left you less confused...
https://www.thirdgen.org/newdesign/vin/
Here are the results for your query on: ***** (before you edited it)
Made in: United States
Manufacturer: General Motors
Make: Chevrolet
Carline Code: F-Body
Carline Series: Camaro (all models)
Body Type: 2 door coupe (hatchback)
Restraint System: Manual belts
Engine Code: 173 ci V6 LB8 (1987-1989)
* is the CHECK DIGIT
Model Year: 1988
Assembly Plant: Van Nuys
Production Sequence: ******
Old Apr 13, 2004 | 11:46 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
yes there are HO's
The HO was actually a 2.8 designation, surprisingly enough. The HO is what ALL of the MPFI models were considered. The only reason they are HO's is because of the Valve sizes being larger than the carbed models (or so I read).
Old Apr 14, 2004 | 05:28 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ditto all MPFI cars are HO though the fiero got HO stamped valve cover I believe.
You could also say any MPFI 2.8 is HO no matter what it came in. car truck van
Old Apr 14, 2004 | 05:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, and the MPFI also got a better camshaft along with the larger-port heads.
The "HO" was really for the '85 models, and it was dropped for 86-up. There was even an '84 HO 2.8 that was carb'd, but I don't know anything about that one.
Old Apr 14, 2004 | 11:26 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
lets see if my memory is correct, 84 HO carbed engine was HO because it actually had heads more similar to the later model v6's w/ the same size exhaust ports as the later versions. don't know if the 85 would have recieved this engine plus fuel injection, if so, it might account for the extra 5 lbs of torque.
