Timing Chain Cover gasket leak?
Old Apr 24, 2004 | 01:59 PM
Twig's Avatar
Car: 91RS
Hi all!
I'm proud owner of 91RS (3.1)
Ever since I bought it (4yrs ago) it had slow engine oil leak.
Recently, mechanic pinpointed leak to timing chain cover gasket.
Engine is otherwise in great shape.
I would imagine this fix would cost a lot of $ due to a labour involved. Is there any alternative / quick fix, or even temporary solution?
Thanks!
Old Apr 24, 2004 | 02:17 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Possible quick fixes include "stop leak" oil products (not reccomended if you like the motor) or cleaning the specific area of the leak really well with a solvent and sealing it with a smear of good silicone RTV. The RTV method only applies if it's the timing cover gasket and not the front oil seal for the crankshaft which is housed in the timing cover.
Old Apr 24, 2004 | 09:04 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Question
WHy don't you just replace the gaskets and seals? It's super easy if you have the right puller. Heck, replace your timing chain while you're at it.
Old Apr 26, 2004 | 07:55 AM
Twig's Avatar
Car: 91RS
Thanks guys.
Part of the problem is that I recently moved to apartment, and I can't work on the car myself (part of building regulations). I have to take it to mechanic even for oil-changes.
I'm going to try silicone RTV tho.
Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
MY87LT
Aug 17, 2015 08:43 AM
