Fuel Pump Location
Old Apr 25, 2004 | 11:29 AM
Super Camaro's Avatar
Car: 88 Camaro
Engine: 5.8L 355ci V8
Fuel Pump Location
Is the fuel pump on an '88 Camaro 2.8 in the fuel tank, or on the engine?
Old Apr 25, 2004 | 11:33 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I have just looked over this whole site and i have come to the conclusion that the search button is broken! I have found at leaste 10 new threads that have been talked about many times before.
Old Apr 25, 2004 | 11:54 AM
Car: 88 Camaro
Sometimes, its just easier to ask it again. And I dislike the search, because when im looking for info on the T5, I cant even search for it cuz theres a stupid 3-letter-word-limit! What the hells the point of that?
Old Apr 25, 2004 | 11:57 AM
br()bert's Avatar
Car: 85 firebird
And most of the time when you ask again its annoying. Besides you are supposed to use the search feature BEFORE you make a new post on any subject. I can see your case with the t5 but this subject is way beyond the 3 letter min.
Old Apr 25, 2004 | 12:16 PM
RedTtop5spd's Avatar
Car: 99 SS
In the tank. Next time, do use the search button. We don't care if you like it or not. Most of us have probably spent 2 hours searching for some little bit of information before we've found it instead of posting a new topic.
Old Apr 25, 2004 | 12:21 PM
Car: 88 Camaro
I am putting my 355 in, and I dont feel like dropping the tank to take the pump put, so what pressure regulator should I use? Or would it work if I put a mechanical pump on and had 2 pumps?
Old Apr 25, 2004 | 03:05 PM
br()bert's Avatar
Car: 85 firebird
You should go to the engine swap forum and read the v6 to v8 swap sticky
Old Apr 25, 2004 | 03:06 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
As much as you'd love to get around it, you're dropping the tank. The V6 fuel pump will leave a 355 starved for fuel no matter HOW you do it.
Old Apr 25, 2004 | 03:11 PM
br()bert's Avatar
Car: 85 firebird
if its a carbed 355, you would need a 3 port fuel pressure regulator with a return line thats it. adjust the pressure to whatever the carb needs and your done. No need to mess with the fuel pump. People have done this 9573405743-57-36843 times in the engine swap forum.
Old Apr 26, 2004 | 09:57 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah ....you can buy a fuel pressure regulator or drop the tank id opt for buying the fuel pressure regulator cause the tank wont like to come out very easily...lol...we spent the better part of 3 hours droppin and swappin on ours....its not a fun ordeal ....LOL
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
