What plugs and wires?
Old Apr 28, 2004 | 02:33 AM
oil pan 4's Avatar
Car: 89 Firebird
For my 85 V6 I need new plugs and wires because all the old ones got burned up in a shop fire along with the hole harnes and ignition.
So far I built a distributor form a peace of crap I got off ebay for $9.
I tosed the cap, rotor, pick up coil, ICM and cleaned a ton of $hit out of it.
I rebuilt it with an holley ICM, some cap and rotor kit I got form summit, a Blaster SS ignition coil, I need to get a pick up coil from napaonline.com and plugs and wires.
So I have a 3.4L with a crane 272 cam (big cam but not real big) plus all the stuff on my web site but the turbo.
What plugs and wires should I get?
Old Apr 28, 2004 | 01:11 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
for plugs go with the bosche platinum 4's cant go wrong there. with wires i have nevr really noticed too much difference between brands. pretty much thicker wires better performance. some nice 8.8mm will do you juss fine.
Old Apr 28, 2004 | 02:36 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
You're prepping for a turbo setup and I'd guess you're likely to be adding a much hotter secondary ignition as a result.. platnum is out (the coatings can melt off) (edit, just saw the blaster SS coil.. DEFINITELY no platinum). AC Delco Rapidfires.. or just about any other normal plug. I personally run 99cent Bosch Supers... just don't use Champion (not that I've got anything against them.. they just pop into my mind as primarily for lawn equipment).
Wires, I wouldn't spend too much on until the turbo setup is done and you know your clearances, however, accel 8.8mm 300+ is obscenely heat resistant.. good stuff. Use a universal kit so you can cut them to fit, and you get 2 spare wires 'just in case'...
Old Apr 28, 2004 | 09:36 PM
oil pan 4's Avatar
Car: 89 Firebird
The wires will have to be as heat proof as posible.
I was also going to have a MSD 6BTM when the turbos go on, or I might just get a 6AL now and hook a boost ignition retard to it later.
Old Apr 28, 2004 | 10:26 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
have you priced some of the braided plug wires yet they are good. i ran a set on my 84 z28 with a 350 and headers never had one melt on me or misfire at all but i payed over 50 bucks for em from summit but i looked at it as money well spent i wasnt replacing burnt wires all the time ...
Old Apr 29, 2004 | 01:20 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Accell plugs
Kem wires
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Brcharrelson
Aug 26, 2015 07:47 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
jbd1969
Aug 17, 2015 07:06 PM
Exxon Limited
Aug 9, 2015 08:13 PM
