tb too small
Old Apr 30, 2004 | 11:53 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
tb too small
yes, i did a search. can i swap a bigger throttle body on to my 2.8 v6? my brother looked at it and started laughing at me. the bastard. anyway...... yeah.
Old May 1, 2004 | 12:56 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
you dont need a bigger tb the stock one is more than enough for the tiny 2.8. He was probably laughing at the overall size of the motor and not at the TB.
Old May 1, 2004 | 04:56 AM
Xophertony's Avatar
Axle/Gears: n/a
his 2.0 has a bigger tb darn 240's
Old May 1, 2004 | 06:09 PM
LT1guy's Avatar
Car: 1987 Trans Am
There is a larger throttle body available through a place in Canada (don't have the link handy, they're building one for Redraif for her modded 3.4). There is no other factory throttle body that is any larger that will work (3.1 and 3.4 are the same size) . Some have adapted TPI style twin throttle bodies, but I question the benefit since they retain the most restrictive part of the air intake...the stock plenum.
Old May 1, 2004 | 07:06 PM
Xophertony's Avatar
Axle/Gears: n/a
if the 3.4L uses the same TB as my 2.8 i think i am doing fine. i'll just tell my brother that the guys in japan that desighned his engine were trying to compensate for somthing they were lacking... in um... other areas of there life .
Old May 1, 2004 | 07:29 PM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
Stock plenum can be modified to take advantage of the larger bore TB, otherwise it is a wasted effort and expense. Here is one that is made by a European fellow that I have on my 3.4 which approx. 58mm
Old May 1, 2004 | 07:54 PM
BitchinRS's Avatar
x55Cam,
What sort of price and is he willing to make more?
Old May 1, 2004 | 10:16 PM
RedTtop5spd's Avatar
Car: 99 SS
I think RSMracing offers a larger throttle body that will fit our little engines as well. Not entirely sure though.
Old May 2, 2004 | 12:13 PM
x55Cam's Avatar
Engine: 5.7L
BitchinRS, I haven't heard much from him in quite a while so not sure if he's still doing them, but the 2.8s were very popular in Finland so would guess that he may still have them.
Here is his email if you are interested and would like some more info:
kimmo.ahola@elektronet.fi
Old May 2, 2004 | 08:02 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
my email that i sent to the adress x55Cam listed got returned to me. anyone else have any luck or problems?
Old May 2, 2004 | 08:37 PM
x55Cam's Avatar
Engine: 5.7L
I'll keep trying to see if I can locate him. He had an '88 Camaro SC at the time but this is going back a few years. Things happen, and nothing is forever, though
BTW, my TB does measure 62mm at the widest point but narrows to 58mm right at the throat where the butterfly starts. I was being conservative as to the actual efficiency and volume that can possibly pass thru at the narrowest point.
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
