Fried ECM???
Old May 4, 2004 | 04:00 PM
fuzzdrummer311's Avatar
Car: 1992 Camaro RS
Engine: 3.1 L MPFI
Fried ECM???
okay so 3 months ago my car was dragging butt real bad, hesitating in first and second gear and dying in rainstorms. I thought it might be the fuel filter and so in trying to change that, i pulled the inj 1 and inj 2 fuses because at the time i couldn't find the fuel pump switch. After that, my car would sit there and crank, but would not turn over. After a month of scratching my head i tried one last time and it started up, but ran like hell. The idle is horrible and every time i barely touch the gas pedal it redlines. It threw me a code 33 (MAF) so i changed the sensor and nothing happened. i also changed the o2 as well. i have spark, air, and fuel (43 psi) , but no engine running. did i fry my ecm or is something else majorly wrong?
Old May 4, 2004 | 08:38 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
One way to tell
get one from a junkyard and slam it in, lol. Mine did a minor crp out on me, was on the 02 sensor circut. I got a good one for 35 bux or so.
Old May 4, 2004 | 09:26 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
you could probably find a ecm in the junk yard for cheap, yards here have alot of 2.8's in them.
Old May 6, 2004 | 01:28 AM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
Not to sound stupid, but clear out ecm by battery disconnection. Run car through some driving cycles and then use the perfect paper clip to check for codes.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
