how to check motor mounts??
Old May 6, 2004 | 10:08 PM
squirrelybird's Avatar
weird vibrations lately...don't know how to describe them, i just know i feel something different as of late. question i want answered is .....
motor mounts....(3.1 if it matters)....how many, where are they, what do i look for to see if they are bad?
thanks,
evan
Old May 7, 2004 | 08:11 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
describe when you get these vibrations. is it when idling? in park or gear? moving or not? if so, what speed and rpm?
Old May 7, 2004 | 09:57 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Fastest way is w/engine running, hood open, drop it in 1st gear, stand on the brakes, tap on the gas pedal (power brake) If the left side of engine raises, drivers side mount is broken. To check the other mount, repeat order in reverse gear. If you want to check the trans mount, put a jack under the tail shaft and jack it up a little, if it's broke you will see a gap in the rubber. You can also here a distinctive thump on hard acceleration and cornering.
Old May 8, 2004 | 06:33 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Re: how to check motor mounts??
thanks,
evan
Just look at them. If they are bad they'll be squished and beat up looking. The engine will sit lower and the clamshell might even be touching the crossmember.
BTW, I hate doing these motor mounts 'cause I can never get the thru-bolt back in. That $hit never lines up right.
Old May 9, 2004 | 08:21 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
SOOoooo......, How long have you been running around without them?
Old May 9, 2004 | 09:11 PM
Engine: LH0 3.1L
Who, me?
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
