How do I find leaky injector?
Old May 13, 2004 | 09:03 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
How do you find out which injector is leaking on a V6 motor? We don't really have a fuel rail that we can pull out to check. Or do we? Doing an ohm test won't tell me, checkinf fuel pressure won't tell me. What else?
Old May 13, 2004 | 09:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello sixbanger,
You check them pretty much the same way we check them on the V8's. Lift the fuel rail off the manifold and have someone prime the pump while you check the injectors for leakage. Here is a breakdown of the V6 fuel rail for you.
Old May 13, 2004 | 09:30 PM
sixbanger's Avatar
Thanks for the great pic, what needs to be undone (from the pic if anything) to be able to lift it out?
Old May 13, 2004 | 09:49 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The two bolts that hold the rail to the lower plenum need to be removed so the rail can be lifted. Might I suggest some small containers or something to catch the gas so it doesn't get all over the rest of the engine?
Old May 13, 2004 | 10:15 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
You'll need to remove the upper plenum also. And if i remember correctly isnt the cold start injector in the rear of the manifold? He'll have to remove that as well or the fuel rail wont be liftable?
Old May 13, 2004 | 11:30 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Bending that pathetic little steel fuel line running to the CSI isn't that hard.
Old May 14, 2004 | 12:19 AM
br()bert's Avatar
Car: 85 firebird
either is breaking it!
Old May 14, 2004 | 08:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Have you read the plugs yet? Maybe one is extremely fouled out (or super-clean)... look for one that doesn't match the others.
You could also prime the pump a few times (on a cold motor), and then pull each spark plug to see if any look wet. Might or might not work, but checking the plugs is the easiest thing to try.
jklein337
Sep 19, 2018 06:23 PM
Steve78LT
Feb 24, 2016 12:15 AM
twest2k2
Aug 24, 2015 11:26 AM
justin57
Aug 20, 2015 07:05 PM
Catcher55
Aug 15, 2015 07:08 PM
