another "what do you think ill run" question
Old May 14, 2004 | 07:25 AM
92RSMuscle's Avatar
75 shot of nitrous
hypertech coil
accel wires
delco plugs
still undecided as to cap and rotor
flowmaster cat back 2.5"
exhaust cutout
underdrive crank pulley
high flow cat
CAI
timing at 8* due to nitrous
A/T
i think its a 3.42 posi rear out of a 90 formula 305 AT
and i need a guess at a time for the car with street tires and with Drag radials.
also i plan on doing some low cost stuff like wonderbar, box LCAs, box panhard stuff like that
and im undecided as to gut the cat or get high flow
and im not sure if its worth it to get a shorter belt and not use the AC or smog, if anyone has seen a gain without ac or smog, lemme know (asside from clean up the engine bay and lose some weight)
Old May 14, 2004 | 07:36 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Is this on a 3.1? If so, depending on tune, I'll go out and say a 14.3
2.8? 14.7!
Hi flow cat > gutted cat
Old May 14, 2004 | 08:19 AM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Anytime you remove drag from the crank pulley, you gain hp. That read end could have either 3.42s, 3.27s or 2.73. If its the 9-bolt, its 3.23s. Just a thought, don't use Accel wires. I had them on my car and I had problems. I switched to MSD wires and the problems went away. I would guess a time but you haven't said what motor you have or the gears.
Old May 14, 2004 | 09:22 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Gutting the cat and leaving it hollow is actually worse. Either do a high-flow, or totally remove it and have a pipe welding in its place.
The empty cat plays with the air-flow/turbulance.
Being his screen name is "92RS" I would assume 3.1
140hp/180tq stock.
Old May 14, 2004 | 10:48 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I think itll explode
Old May 14, 2004 | 06:00 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I'll go with Doward's answer, but tack on a few tenths...just so you won't be dissappointed.... Sounds fun though, I'll have to get me some spray.
Old May 14, 2004 | 06:06 PM
br()bert's Avatar
Car: 85 firebird
wish i had some nitrous, it would be cool to see how much a 2.8 could handle before it blew. I already have a 2.8 to try it on
Old May 14, 2004 | 10:52 PM
92RSMuscle's Avatar
thanks guys im really happy you guys are giving me serious answers and not tellin me to get a 3.4 or a v8 or something.
its a 2.8, but its been rebuilt andi think taken over to 3.2
ok, so its decided, highflow cat. which ones a good one and about how much od they go for?
75 shot should be totally safe on the motor right?
and the underdrive pulley is a go,
and msd wires not accel right?
Old May 14, 2004 | 11:01 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
what person would put a 2.8 in a 92 RS that doesnt make too much sense i think u mean 3.1?
Old May 15, 2004 | 12:20 AM
92RSMuscle's Avatar
blew up the 3.1, we had a 2.8 bored to 3.2 with 10K sittin on the shop floor, guess where that went, so it makes sense if ya know the history of it. besides, what do you think ill run?
Old May 15, 2004 | 12:32 AM
br()bert's Avatar
Car: 85 firebird
not to much faster.
Old May 15, 2004 | 01:03 AM
92RSMuscle's Avatar
na i was asking him what he thought id run. i know there wont be much of a difference with a 3.2 sorry i think i worded it wrong.
Old May 15, 2004 | 01:53 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
3.2, eh? Exactly how much did you punch the block? How much reinforcement on the cylinder walls?
At any rate.. that depends entirely on how it was built if it were punched that far.. titanium sleeved, low 14s... anything else, high 25s coasting most of the track, once...
Old May 15, 2004 | 05:03 AM
Engine: 3.4L 207 V6
Just tell us that you had the block resleeved instead of boring it. Those cylinder walls aren't thick enough to bore and then spray.
Can you say "boom"?
Old May 15, 2004 | 07:06 AM
92RSMuscle's Avatar
see now its this **** that pisses me off. the guy who got the engine done,. does not know a *** damn thing about it. he TOLD us it was bored to max and rebuilt. but knowing the history of this clown, iunno. its like i ask him, did you buy the engine new or have it rebuilt, hes like iunno i just threw it in there, besides, whats the difference.
im gonna go scream at him in a half hour.
Old May 15, 2004 | 07:14 AM
br()bert's Avatar
Car: 85 firebird
SO i was right the first time
Old May 15, 2004 | 08:06 AM
Dale's Avatar
Engine: 350 S-TPI
difference between a 2.8-3.1 is the crank, not bore.
Plus 5hp and 20tq
Old May 15, 2004 | 12:43 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Well, since you're unsure of the specs, here's the gory details.. if it's a 2.8 block with a 2.8 crank, bringing it out to a 3.2 would involve a *minimum* of a .200" overbore, which is absolutely unheard of.. normal max overbore is .060"
Old May 15, 2004 | 02:20 PM
7plagues's Avatar
i think if its bored out to the max and u dont have forged anything sumthin is gonna blow... sorry just personal opinion no actual knowlege.
Old May 15, 2004 | 03:28 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Forged components have nothing to do with the cylinder walls being too thin and blowing out.
Old May 15, 2004 | 03:42 PM
7plagues's Avatar
sorrry like i said no actual knowlege...but yea the cylinder walls. but with only 10k it might be ok.
Old May 15, 2004 | 04:09 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Milage has nothing to do with it either. 1/10 of an inch off a cylinder wall is alot. Let's say there's 1/2" of wall between each cylinder.. sounds like alot (and it probably is a little high) .. now let's look at the #1 and #3 cylinders specifically for example.. you bore the #1 cylinder .200" over.. that's 1/10" off the wall thickness all the way around.. now instead of .5" separating 1 and 3, there's only .4"... now bore #3 the same amount.. only .3" separating the two cylinders.. that's almost half of the original wall thickness gone... and as I said, I think .5" is a little high (no block laying around to measure, too lazy to search it up)... factor into this the wall thickness separating the cylinders from water jackets and the crankcase, and it's a recipe for disaster.
Old May 15, 2004 | 04:11 PM
7plagues's Avatar
thx for educating me tech i now know more but yea ive never heard of .2 bore on a car.
Old May 15, 2004 | 07:43 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Hopefully he's just an idiot and it's a plain-jane motor. Or a light boring. Somebody ought to tell him boring is for repair not for power.
Well, it's either blow or go. Either way, get it on video. I'd love to see.
Oh and regarding your first post....."still undecided as to cap and rotor"....come on man! It's not that hard! Lol, just get something that matches and has either copper or brass terminals. It's not rocket science!
Old May 15, 2004 | 07:46 PM
br()bert's Avatar
Car: 85 firebird
like you have many avalible anyway
Old May 15, 2004 | 09:48 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
CAP AND ROTOR = MSD p/n 8430 please don't try to tell me that the 4.3 one won't fit. i have this one on my car. that p/n does say its for a 4.3 but it WILL WORK on the non-carb'd 2.8, 3.1, and 3.4s.
Old May 16, 2004 | 12:23 AM
92RSMuscle's Avatar
thank you, a part number was all i needed.
well i did some talking to him today, some yelling rather. and i found out some info...its a jasper rebuild.
so we are gonna call up jasper and see if they have the specs for it. if they dont, we are gonna have to find the reciept and hope they have something on there. id rather not take off the heads if i dont have to.
keep the comments coming, ill have to let ya guys know come monday or tuesday
mike
Old May 16, 2004 | 01:01 PM
Nixon1's Avatar
I highly doubt Jasper would "bore it to the max". That's just something stupid people say to make it sound better. You're probably ok....
Old May 16, 2004 | 11:21 PM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
If you can, with your unique combo, replace converter with a straight pipe. You will be farther ahead. A company on ebay that advertises from time to time has straight pipes for our v-6's.
Old May 17, 2004 | 12:16 AM
br()bert's Avatar
Car: 85 firebird
so does most any auto parts store. Cut the cat out put the pipe in.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
