Smoke under the hood
Old May 21, 2004 | 01:31 PM
Bethsacamarogrl's Avatar
Car: 1987 Sports Coupe Camaro, Red w/ T-tops
Engine: v6, 2.8 and proud of it!
Transmission: Auto of course!
Whenever I drive my Camaro, (1987 Sports Coupe, 2.8 V6) it smokes under the hood. My dad said its probably just burning oil, but this has been going on since the beginning of winter. Does anyone know what this could be or had the same problem? Thank you. If you could email it to me or post it here. My email is cowgirlupinacamaro@yahoo.com
Old May 21, 2004 | 01:49 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Thes engines are known for the valve cover gaskets to leak in the rear.
One of the rubber dromits that goes in the valve cover has dry roted.
Exhaust leak in the engine bay?
Does it loose oil over an oil change?
Smell like oil?
Blueish tint to it?
ticking noise from under hood
visable leaks of anything?
Any puddling of any fluid on the ground when parked over night?
Old May 21, 2004 | 05:08 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Most likely it is the distributor o-ring.
Here's a message that I found using the SEARCH function on the site about this exact problem. I used to burn a quart a week because it leaked so much.
https://www.thirdgen.org/techbb2/sho...tributor+oring
Welcome to the boards!
FormulasOnly
Jul 23, 2018 08:47 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
