Limited Slip Differential
Old May 24, 2004 | 04:11 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Hello Everyone,
Just wanted to ask you guys if anyone on here has used an LSD on their V6. I plan on purchasing one from summit racing. The company Eaton makes one that would fit our cars. It's 439 bucks so before i go through i just wanted someone elses thoughts.
"Live Fast Drive Faster"
Old May 24, 2004 | 05:16 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i've got a zexel torsen posi from SLP. it was $120 and i love it!
Old May 24, 2004 | 07:45 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I have never used one but that pro trac system I saw on HP TV was cool. It will fit / go into any rear end, no spool chang needed. Its is $4-500 but anyone can do it in a few hr in the drive way. It a neat unit as when turning it will act like a stock peg leg rear, but in a straight line both will lock.
My self I like that the best. Even a limited slip spool can be dangerour in bad weather and a spool n axel change isn't fun or easy.
If that one is similar, the price is about right and worth it.
Post a link to it plz.
Old May 24, 2004 | 07:52 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
MakeitQuick92RS yes, an LSD will help traction issues and for the v8 crowd, the 3.8's respond quite well to having traction, the best would be a spool or a locker, but you lose streetability, so go with a zexel or perhaps a nice protrax.
Old May 24, 2004 | 08:01 PM
Xceleratemaro's Avatar
have you thought about a spohn ajustable Torque Arm! or even relocation brackets?
here are some links..http://www.spohn.net/product.cfm?productid=1300
http://www.spohn.net/product.cfm?productid=1290
Old May 25, 2004 | 01:21 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
My personal votes go for a zexel or auburn limited slip unit for general street, protrax locker if you're looking for sheer straight line performance. There are other suspension modifications to help keep the wheels squarely attached to the pavement, though. Tubular LCAs + relocation brackets, adjustable torque arm (MAJOR), decent springs, good shocks, etc etc...
(For those of who whose post remained but was edited, if you'd prefer the post be deleted so you can start fresh, please pm me )
Old May 25, 2004 | 01:38 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Now that I look at how much you're looking to pay for that Eaton, I think it's neccessary to point out you could probably walk away from a junkyard with a 3.23 posi disc brake rear and master cylinder for ~200, and still have enough cash to buy nice tubular LCAs and brackets...
Old May 25, 2004 | 02:13 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Auburn here with 3.23 road gears/I dropped down from 3.42's.
Old May 25, 2004 | 08:59 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
IF you do go to a yard dont just assume the rear you are taking has good gears in it, check it out, many v8 cars have 2.73's etc. put some 2.73's in a v6 car and i dont think you'll like the results.
Old May 25, 2004 | 11:11 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Yup. I know someone that just totalled their GTA. has posi in it, but 2.73 or whatever in it, rear discs too. Think I'll stay w/my 3.42s, but trying to get that aluminum drive shaft, only he knows it's aluminum too
edit: SInce you have the newer rear, try looking up at one of the SLP take offs
edit: I caint find teh take offs now, maybe there aren't anymore.
Old May 25, 2004 | 11:33 PM
Akshay's Avatar
Won't a posi from a v8 camaro fit a v6? Slightly used one ofcourse.
Old May 26, 2004 | 10:29 AM
br()bert's Avatar
Car: 85 firebird
Yes but like said above you just dont go rip one out of a v8 and throw it in your v6 and asume that its better, Sure you might get a posi now but you also could get worse gears like 2.73's etc.
2.73's and a v6 motor = No No
Old May 26, 2004 | 12:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The SLP Take-off's are gone...
Old May 26, 2004 | 12:39 PM
i bought less than 2 mounths ago.. the part # is 64501t i should have bought more when i had the chance!
Old May 26, 2004 | 06:58 PM
Akshay's Avatar
No no. I'm talking about just the limited slip, and not the gears.
So a limited-slip from a z28 won't bolt to the 3.42 gears?
Old May 26, 2004 | 09:49 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
AM91
how does the zexel torsen work? do you have to pull the whole carrier or do you just replace the 4 gears in the center of the carrier? id rather stay away from reshimming and all that crap if i can, lol.
Old May 26, 2004 | 10:26 PM
Car: 91 Camaro
the ZT unit works good. it has, like, worm gears that run the length, well width i guess, of the carrier to the side gears. with a load on it, the worm gears will force the side gear out, to the side of the unit, therefore, locking it. that's my understanding of it anyways, someone correct me if i'm wrong. there's no way to put ZT insides into a open carrier. good luck replacing the guts to get posi. i could be wrong but i've never heard of being able to do that except to go, basically, mini spool...aka welded carrier. reshimming it wasn't really hard, just a bit of a pain and time consuming but not necessarily difficult.
Old May 26, 2004 | 10:32 PM
drdave88's Avatar
Engine: 6.0L
as posted above, the pro trac system on HP TV just replaces the 4 gears in the center of the carrier. i didnt know if zexel was the same or not. but you told me what i needed, thanks. im gonna look into it.
Old May 26, 2004 | 10:34 PM
Car: 91 Camaro
sorry, i missed the post about the pro trac.
Old May 26, 2004 | 10:38 PM
drdave88's Avatar
Engine: 6.0L
does yours click a lot around turns?
Old May 26, 2004 | 10:41 PM
Car: 91 Camaro
never noticed it clicking. if you get on it (the gas) enough while turning, you can feel the inside tire trying to skoot (sp?) a little but nothing major.
Old May 27, 2004 | 01:06 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep it just replaces the spider gears. It is "pricy" but super easy to install. dual disc is nice but that is what I would get. like said above most stock dual disc are gona have crapy gears for a 6.
Old May 27, 2004 | 12:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey, I noticed that too when I had the posi rear. (moment of silence for the Eaton gov-lock POS) The car cornered better, I thought it was just my imagination!
You guys gotta cut the crap, now I want to buy a new posi... too bad I've gotta pay off the plasma cutter first. Damn! Time to search ebay
Old Jun 21, 2004 | 09:07 AM
CrazyHawaiian's Avatar
Car: too many ...
Do they make a mini-spool or spool for the V6 10 bolt rearends? I got an open V6 10 bolt rear (from an 88 SC) and I want to experiment with a locked rear hehe. I looked for a mini-spool online but I only see them for 28 and 30 spline. The V6 rear in 88 is different spline count right? (not sure, but I think 26 spline?). Anyone know?
Old Jun 21, 2004 | 09:15 AM
Car: 91 Camaro
i think it was 88 or before when they changed the 7.5" 10 bolts to 28 spline axles. someone else can jump in on that one. but, the rear end for the v6 is the same otherwise, even if you do have 26 spline axles, you can get a set of 28s to put in it, just make sure that they are from the same width rear end and you'll have no problems. for that matter, why not just weld your open carrier?? that be a lot easier.
Old Jun 22, 2004 | 12:00 AM
Car: too many ...
I did some more looking and found that both Richmond Gear and Summit Racing Equipment make mini-spools for the 26 spline 10 bolt rearends. I'll probably go with the Richmond part for $89, but gonna make sure to count the splines in the axles before ordering since 88/89 was a switchover year.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
