Major problem (i hope not though)
Old May 30, 2004 | 09:26 PM
chevytruck68's Avatar
Car: 86 camaro
Engine: 2.8
Transmission: 5 speed
ok guys i have a problem i need help with. im pulling and changing the BLOWN motor in my wifes 86 camaro tomorrow. i got a donor car that is an 88. they both are the 2.8 v6 my problem is the 88 is an auto and my wifes 86 is a 5 speed so i need to change the flywheel. but i did some checking on the Parts America site and found out the the part numbers are different for the 2 years. but when i scrolled down the list on both they sell aftermarkt flywheels and they are the same part numbers for both years. I need to know if the flywheel off of the 86 will work with the 88 engine and not throw off the balance or something. otherwise ill have to wait to do this swap till i get another flywheel.
Old May 30, 2004 | 09:32 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I wouldn't go by what Parts America says. Call a Chevrolet dealership and ask them. I'm pretty sure that the 86 had a balanced flywheel. The flywheel from a dealership would be the best choice, no guessing
Old May 30, 2004 | 09:45 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
The 86 flywheel won't work. However, I think you might be able to have the 86 flywheel neutrally balanced and then you can use it.
Old May 30, 2004 | 09:54 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Precisely. 82-86 are externally balanced, 87+ are internally balanced. Gotta get that thing neutral balanced or grab a new flywheel for an 88 motor (autozone stocks them for about 90 bucks)
Old May 31, 2004 | 07:55 AM
Car: 86 camaro
Engine: 2.8
thanks guys not exactly what i wanted to hear but better to know than screw it up.
Old May 31, 2004 | 11:40 AM
TechSmurf's Avatar
Engine: LS1, Scrap
If it makes you feel better, the changes coincide with a move to a larger journal crank which has a tendancy to be far more durable than the old style...
Old May 31, 2004 | 11:43 AM
Car: 86 camaro
Engine: 2.8
advance auto has a new one for 45.99 plus 40 for a core which i dont have so 86 plus tax. and i called some salvage yards here and found one that wants 80 for a used one so i guess ill be gettig that new one have to wait a week to get it though
stalkier
Aug 21, 2015 01:54 AM
Bryan F
Aug 18, 2015 02:28 PM
zeitghaist
Aug 18, 2015 07:33 AM
92camaroJoe
Aug 13, 2015 06:07 AM
hokis
Aug 9, 2015 03:57 PM
