Coolant Temperature Sensor throwing a code
Old May 31, 2004 | 10:04 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
Okay, got a code 15 (coolant temp sensor) out of my ECM on my 1984 Camaro w/ the 2.8 2bbl motor. Here's the deal: the check engine light only came on when I put the pedal to the floor to pass someone. It did it on two separate occasions about two weeks apart. Does it sound normal that the sensor could be bad and only trip the light under heavy acceleration? Anyone ever have this happen before?
The sensor is cheap enough, so I'll probably just buy it and see what happens, but I just want to know if someone thinks that there's another problem from what I described.
Old Jun 11, 2004 | 04:04 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Are you experiencing some other unnormal problems with the car?
Bstrang6
Sep 8, 2015 04:29 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
squiggy2
Aug 9, 2015 09:30 PM
